Come on Brian. It is ok to pump up your chloresterol level a little. Use hot oil pan fry and dip banana in the pan cake mix before frying. Banana should only be 10-20% ripen though.I do have an air fryer!
Hi Brad. I went through quite a few audiophile cables, Siltech, Crystal, Gobel, MiT Articulation SHD, Kuro, Odin 1&2, Vyda, etc. So much money was lost. Only gain is experience. All audiophile cable especially uber ones aim to "show" the best sound in every parameter. I don't need Ronaldo or Messi of cable. I only need cables that play "normal" more team work with the rest of my system. Money is also the issue. I no longer want to spend a lot more on cables. Placement of my equipments require lengthy cables. I am fortunate that expensive audiophile cables don't seem to fit my sonic preference now. And I am very fortunate to have ddk guiding me on equipment selection all along. Cheap and good is difficult to find. Ddk helps me short cut the learning curve. But I would not realize what is what on cable if I have not spent shit load of money on uber cables before. I am using cables that David sent me to try. They are not all pro cables. The speaker cables are Denon that could only be found in Japanese used market. Interconnects are Gepco and Belden. I don't think David is using Gepco personally in his system. I know he is using Belden. He only gave me one Belden because it is the old model that he himself cannot find more. You and Bill heard from videos that at least they don't make my system sound less interesting. My approach is no technical one. I just use what works in my system regardless of price. Pro cables don't seem to do the showoff thing as much as audiophile ones.
Ok. You tell one. I tell one. I am finding Gotham GAC4/1 interconnect between my phono and preamp works marvelously. Previously I had ddk's Gepco between these component before. The Gotham after four days constant playing displays more liquidity, more natural high, better lay out of detail (not more detail) and a little quieter than the Gepco. Physically the Gotham has a better cable sleeve than Gepco. I am still using a long Gepco between preamp and amps. My first impression of Gepco was a sense of space, depth and impactful drum. All the pro cables I tried did not give me impression of different stage and placement like Gepco. You mentioned you had Gotham too but did not say which model. I tried Gotham GAC2 and GAC4.I found in my audio "junk drawer" some old Belden 497.MkII speaker wire from Japan. I believe it is tinned copper, so it won't corrode and I don't know if it is still available or not. The ends are not terminated and so I trimmed off about 2 inches, and stripped away some more of the outer jacket. The bare stranded wire just wraps around the binding posts which are tightened down. Eliminating spade or banana connectors should nominally be a win anyhow. I'm using it in my secondary mini-system and gave a listen last night. I have to say, this is really a nice sounding cable. I thought maybe it was going to cast a darkness over everything, but that isn't happening. It's open and natural without sounding muddy. It has high end sparkle and lower end weight and texture. All the detail is there. I'm going to keep this stuff in my system for a while and see if anything changes. I also now purchased from Ebay Japan the current version of this cable which is Belden 9497 just for fun. I'm not sure if there is any difference, but at some point after it arrives, I may try the newer version and see.
Added: Some of these cables are directional.
GAC1 is ok but quite different from GAC2 and GAC4.I have some GAC1 RCA interconnects. Haven't used them in probably 5 years. I should try again. I build mine to be directional also. Only because I don't like the shield connected at both ends, so I solder it only at one end and mark it so that I know which end is which. I prefer the drain connection at the source end.
Looks to me like GAC1 is the unbalanced cable (single conductor) which GAC2 is really only different in that it has two conductors. It should otherwise be the same cable and for unbalanced RCA cables, GAC1 is all we need. GAC4 looks like a star quad for XLR?GAC1 is ok but quite different from GAC2 and GAC4.
No Thanks Brian.Edit: If you want, you can remove the RCA outer case and show me how they are soldering the 4/1 for unbalanced connection.![]()
In my limited exposure of these pro cables. I find the Mogami and Belden sound less different to one another. Both Gotham and Gepco has enough their own dna to distinguish themself from the tested bunch. These pro cables don't give big delta of difference comparing to one another as when comparing expensive audiophile cable that I find all of them have strong stand out character of their own.My old Neumann vinyl mastering rig had some Gotham, some Neumann marked cables. The console had Belden where repairs had been made as that was what Columbia techs had used...
I have not recommended an album in a while. Here is Carmen McRae The Great American Song Book. It is a double disc live album. Great sound. Great Live performance in a very friendly atmosphere. Atlantic label. You dont need to like jazz to like this album. It is just very enjoyable. So alive.
Direct from EMT phono. I wont do video comparison just to agitate Bonzo and leave him skeptical.Very nice. I can feel the ambience down my iPhone lol. Is this the DST through the juicy SUT or direct EMT? Have you got this recorded (or please may you) for MS direct to EMT?
I buy records almost everyday. I just dont post interesting album much lately because it requires posting video to give a glimpse of the album.if you’re frequently sharing albums that you like than your hifi gear is sounding great -at least for your taste-. it’s a good indication of how it sounds. another good indication is that if you’re buying more new records or wanting to buy.
I try to limit video to minimum these days. Only enough to back up what I post. Dont want to annoy people who dont like video too much.
