the three most important improvements for optimized sound guide are safe, voice coil, phase plug and the diaphram
So you changed all those from the original design? Did that get you up to 20k? I haven’t seen anyone get it above 16-18k yet.
if you had informed yourself then you would know that these are manufacturer specificationsSo you changed all those from the original design? Did that get you up to 20k? I haven’t seen anyone get it above 16-18k yet.
I’d like to ask that question…..at what efficiency is the 20K achievedif you had informed yourself then you would know that these are manufacturer specifications
would have been nice if you had asked me at what efficiency the 20K are achieved
yes sure that I have also taken it that way I did not mean to be rude, I also see so 16K-18K are a very very good value it needs not more than that ... and if we measure our hearing then we do not even need thatDon’t worry - I was attempting to be polite and take some interest. Good luck with your venture.
nice question fantastic, up to 17.5K the frequency response is very nice and as it should be around 100db.I’d like to ask that question…..at what efficiency is the 20K achieved
of course if you "shelve the driver to death" you might get there,
between 17.5 and 20k the efficiency is 99db at 17.6k and 92db at 20k
87db @ 20Hz and 91db @ 30Hz and 99.4db 77HzWhat sensitivity is the system at 20hz on the other end?
Wowza!the price is $ 174,500
However, this sounds hard like a normal high-end speaker with a multi-way crossover or a multi-way horn with a hi-fi speaker as a model.Morning Gunter. Is this anechoic measurement? If so what is the frequency response +/- 3dB and +/- 6dB?
Best.
Have you listened to the videos of the 18FH ?
Hi Matt,Would be nice to compare vs the best version of the Aries Cerat Aurora.......
Matt
Hi BillHi Gunter,
Yes I have heard several videos of the 18FH.
Best.
As an expert, how would you build a horn?of course if you "shelve the driver to death" you might get there, but a what cost
Best Günter
that's the sound without components in the signal path.
