I'll have to think of a better way to describe it. But it sounds pretty artificial to me.
Hi Folsom,
I've heard tube amps with harmonic structure disproportionate to the fundamental. This could be for any number of reasons, but it's easy to hear. An analogy would be stringing a guitar with six different types of string and then playing a chord in which the harmonics generated by each string caused the individual notes making up the chord stand in contrast to one another in an enharmonic way (like it's part of a different chord/chromatic structure). It makes things sound more "detailed", not because there is more detail, but because the structure of the harmonics is out of balance with the fundamental and one another.
It's not too dissimilar to low-Q EQ boosts on harmonically complex instruments, like, say a piano. Non-judicious use of non-linear-phase or minimum-phase EQ will significantly alter the phase relationship between pitches resulting in a more "detailed" sound that can come across as "unnatural" or "artificial" (i.e. "hyped").
I've also experienced it with Kondo litz cabling, which seemed to emphasize certain harmonics in a disproportionate manner depending on the complexity of the chordal structure (the usual caveats of "in my system, with those particular components" apply).
Is that what you're describing?
