From Wadax. I don't know that others do anything like this.I think if you are talking about Taiko TAS/XDMS for changing the data stream, it is more reasonable. What do you think about other chips? You think CDPs don't have error correction technical or interpolate signal? All of companies have their own technicals, please remember that.
It’s all a matter of preference so as long as you’re enjoying the whole experience and listening more then you’re on the right track.
Wadax technology is founded on the unique musIC process, a sophisticated feed-forward error correction system that operates in the time domain. By mapping the error mechanisms of a chosen DAC chip under load using Adaptive Delta Hilbert Mapping, we can develop an algorithmic that examines the incoming signal and calculates the induced error (both linear and non-linear) that will result. By applying an inverse signal at the input we can real-time correct for the time and phase error that is so musically destructive in other, conventional decoding systems.
This process requires a massive number of mathematical operations and considerable datatransfer: 12,8 GBytes/s. Processing is done at 128 bit internal resolution to precisely render the output and generate the smallest feed-forward corrections. The result is measurably and audibly the most natural and musically communicative digital decoding currently possible – something that’s obvious as soon as you hear the Atlantis REFERENCE DAC.
Now go to innuous and MSB sites
STATEMENT Next-Gen - Innuos flagship music server - for audiophiles
The STATEMENT Next-Gen Power Supply Upgrade is the result of Innuos ongoing Research and Development efforts: it has custom-designed Ethernet and USB Reclockers with 3ppb OCXO clocks.
innuos.com
The Select DAC - Features
The Select DAC Features. Starting with an 85lb plate of ‘Kaiser Select Precision Plate’, material is machined in our own in-house CNC shop. After eight hours of machining, 85% of the aluminum is removed, resulting in a 17lb finished product.
Do you see anything referencing error correction software, or is it all the PS, Case work, quality components. Maybe I missed something.
