Gryphon announcement!
HughP3
416
652
325
63
per facebook post from Gryphon
amadeus
312
381
255
XV-1
3,617
2,628
1,860
Sydney
LL21
14,430
2,517
1,448
WOW! Quite an interesting amp...450 pounds in weight for the single-chassis stereo amp and 900 pounds for the monos! 1 million microfarads of capacitance for the stereo and 2 million microfarads for the monos. Looks like 225 watts pure Class A Watts into 8 ohms...and then 225 watts doubles all the way down to 1 ohm 1800 watts...and knowing Gryphon (and based on their other amps), it doubles again into 1/2 ohm so 3600 watts into 1/2 ohm Should be spectacular.
bonzo75
22,639
13,668
2,710
London
They read that Marty and LLoyd, and maybe Abeidrov bought the Mephisto and announced a new amp to tease them for next year upgrade
LL21
14,430
2,517
1,448
Hah!
sbnx
1,205
1,357
290
That should be enough to drive the Alexx or XVX or ANY speaker with no problems. Might need to upgrade the wiring in the house to 8 gauge from the panel to the amp.
Reactions: Mr Rickz
DasguteOhr
2,432
2,611
645
Germany
Amazing amp ,It has always been a good idea to build the power supply of an amplifier in such a way that the amplifier does not notice the connected load (loudspeaker) or something changes.:p
bonzo75
22,639
13,668
2,710
London
andromedaaudio
8,486
2,836
1,400
Amsterdam holland
just what we needed - more $250k/pair amps lol
What you need is a high eff / high imp speaker design( non horn :) ) then you can have all the gryphon goodies with an essence.
The amp manufacturers cater to speaker design deficiencies afaic.
Of course you need a 600 hp engine to make a 2,500 kg car react fast .
What one could also do is built a 1300 kg car and drive it with a 400 hp engine to get a much more agile / fast combination
Reactions: wil
bryans
920
876
250
I agree. I can't even imagine what this hobby is going to look like in another 10 years. Seems like 50K amps will be considered "budget" gear o_O
Kingrex
2,939
2,403
350
They look to be 240 volt 20A per channel. Thats equivalent to 40 amps per channel in 120 volt. And you avoid the requirement for AFCI breakers. If your subpanel was 20 feet away 10 awg would be fine.
I still think the plugs should have been a twist lock. Much lower insertion losses, larger contact aurface area, positive engagement. I don't understand the fascination with IEC style cord ends.
Reactions: dandylinpsst
16,210
13,672
2,665
I think Mephisto monos already were able to drive any loudspeaker with no problem.
16,210
13,672
2,665
This new amplifier certainly is an interesting development. It suggests that Gryphon believes there is no sonic penalty to adding on more and more output devices.
Or if there is some sonic penalty to increasing the number of output devices do the other improvements like additional capacitance and noise management techniques offset equally or more than offset such sonic penalty?
I will be very interested in reading reviews and reports comparing directly the sound of the Mephisto to the sound of the Apex!
PS: Leave Marty alone. I bet his back is hurting right now just imagining the size and weight of the Apex!
Reactions: Mr Rickz
marty
4,206
2,520
United States
I can't even imagine what a 450 lb amp looks like, but I know my room cannot accommodate the crane you will probably need to move them. Nice to see Gryphon evolve after Flemming's retirement.
Lagonda
3,509
4,818
1,255
Denmark
To bad their latest amps are lacking the good looks that Rasmussens designs had. That big triangle on the front is not attraktiv. Seems like output and size wise they are following in the footsteps of Dan In his maddest Master Reference Krell days. :rolleyes:
sbnx
1,205
1,357
290
I was just thinking ahead to the next generation of speaker where the minimum impedance is 0.25 ohms and stays below 1.5 ohm for much of the frequency range. There seems to be a trend of lower and lower impedance in speaker design where the designers are relying far too much (IMHO) on brutish amplifiers to be able to drive them. Also, the quoted (2.83V) sensitivity rating is extremely misleading for these low impedance speakers.
Sorry for the rant. I do feel better.
Actually, I am more curious about the preamp and how it might mate with the Mephisto.
Reactions: tima and christoph
