Before you change your cables, can I make a suggestion?Hi guys,
I'm looking to try new speaker cables and interconnects in my system because i find my Gryphon cabling too clear for my speakers and the treble tends to be fatigueing in the long run.
I need to try 100% copper cabling only and the ones that come to mind are Tellurium Q Statement and Audience Front Row.
I only need a set of speaker cables and one set of balanced interconnect.
Please let me know if you have suggestions so i can get a smoother sound thanks.
Are you using an aftermarket LPSU on your internet box?
I'm not sure what you're hearing but if you haven't done it, try a LPSU on your ISP box, turn off the wifi and it will take off any harshness or fatigue due to high frequencies.
If you haven't, let me know, I have a few suggestions and I can explain my setup, it really worked like a charm for me.
