SACD recordings
Bruce B
Apr 25, 2010
7,009
521
1,740
Snohomish, WA
www.pugetsoundstudios.com
I've been listing to some SACD discs lately and can't believe how bad they sound. So I did some investigating. Theres a few that I'll pick out for you.
Here is a disc where the DC offset is off the charts. Not to mention the noise from 50-100k.
Here you have a signal overmodulation from a loud drum strike.
Bad mastering jobs?
Could be a pattern depending on who did the recording/mastering for each label.
No.. one was a Soundmirror/Mark Donahue project and the other was a Classic/John Newton project.
I've seen this with Telarc, PentaTone, Chandos and lots of others. Seems every label has a few out of spec.
Well, as Joe E. Brown said as he embraced Jack Lemmon (in drag) at the end of Billy Wilder's "Some Like It Hot:" Nobody's perfect!
Hi
I understand the subject is SACD (Don't cotton much to the format as you should know by now) .. How did the corresponding CDs (if any) sounded ?
Hi
Well the loud passages that over-modulated sounded like distortion/crackle. The other's just didn't have any life, very 2-dimensional and not pleasant to listen to.
Bruce, I wish you would name the titles. I'd like to know if I have them and/or to avoid them.
Gee, I thought it was Jonathan Stokes, not John Newton who worked for Classic Sound. But you are right about lifeless. I find everything done by Classic as you described, and their multi-channel recordings particularly poor. Classic seems to have no use for the ITU microphone alignment. Their 5.x recordings are basically faked quad.
Have I just entered Bizarro World? I was hoping to pick up a few gold nuggets from the Whats Best Forum (not the Whats Worst Forum). Can you provide a healthy list of some SACDs that show the best SACD has to offer.
I'd stick with Channel Classics, PentaTone, Mercury, Marinsky and LSO Live
Thanks. These are all great labels for classical music on SACDs. What would you recommend for non-classical music like jazz, instrumental, pop/rock or world music on multi-channel SACDs? Or do you think that multi-channel non-classical music will be better served on other formats like DVD-As or Blu-ray?
For jazz, I'd go with Fantasy, Verve, MFSL and Analogue Productions.
I'd stick with DVD-A for Rock/Pop. There are a couple of MFSL, but it's slim picking!
What about Tom Jung and DMP?
Think I found the worst recorded jazz SACD I've ever heard. I can't stand to listen to over 10 seconds of it because it's recorded/mastered so hot, the clipping/distortion will actually hurt you. I had high hopes for these.
James and Lucky Peterson - If You Can't Fix It
I totally agree on Verve, MFSL and Analogue!!!!!
