Affordable High End Long Interconnect
Uwiik
388
360
135
43
I need 10 m long RCA interconnect to move my TT closer to where I am sitting. Normally I would just get Siltech Crown/Double Crown/Triple Crown but 10 m of Siltech is just out of my range to even consider. What other cable would you guys recommend? It’s going to connect my Phono to my Preamp. I have Kuro, Kondo LS41, Acrolink and Goebel on my short list, Kuro piqued my interest the most but I have no idea how to buy the Kuro cable. Any other solid but still affordable recommendations?? Thanks
audioblazer
766
208
1,605
Malaysia
Check out iconoclast cables
andromedaaudio
8,505
2,852
1,400
Amsterdam holland
Roland Black series , it will set you back around 20 euros depending on length , its sold in music instrument and recording equipment stores.
Iow used by the people who make the music you listen to .
Reactions: twitch
DasguteOhr
2,463
2,637
645
Germany
I have a question what kind of phonopre you have, 10m will be difficult. The Phonopre must be able to deliver power and have low resistance
DasguteOhr
2,463
2,637
645
Germany
I know only one tube phono that drive easy 50 feet cables, Innovative audio use the same like the big Lamm linepre as output stage two 6h30 tubes parallel per chanel.
Uwiik
388
360
135
43
Right now I have Jadis JPS3 and will be replacing with either EMT or HSE, most likely it will be HSE.
Uwiik
388
360
135
43
I have listened to the HSE phono with 10 m long Luna cable to the preamp and it was as good as it gets, I think in the case of HSE long cable is fine.
Reactions: DasguteOhr
Uwiik
388
360
135
43
Kuro (how to buy?), Skogrand and FTA those are the strong contenders right now, seems like very high end to begin with but price doesn’t double as rapidly as the length increase. Advice?
