Hey Ron,
Very early stages but I have considered room, budget, my own (very limited) experience (and far more limited technical knowledge) to come to the following big picture framework for my goals:
1. Deep bass is important to me because:
- Sub frequencies (sub 35hz) in my understanding and experience deliver an enveloping sense of space of the venue ALL around you
- Great for movie soundtracks where our sound system is also attached to the film projector
- At super low volumes, it is remarkable how much a super-low noise floor combined 'unlimited' deep bass enables you to feel completely enveloped, a nice chest-thump and a fulsome sound
at 'volume 1'
- My observation and experience is one reason people keep turning up the music is because they are looking for slam, that sense of satisfaction from power/depth/grunt. Over the years, I find I am turning DOWN the system more often because I 'get it all' at lower volumes. Equally, if I do turn it up...it is a marvel but I dont feel any lack when I turn it DOWN. For me, that is definitely due to super low noise floor combined with powerful subterranean-bass that provides that solid foundation at all levels.
2. Oh and also because I just love deep bass.
And once you hear it done much better...it is always very very hard to go backwards
3. When working with 'full range speakers', there are still some important factor about what makes a subwoofer "necessary" (for me)
- Deep bass takes a LOT of power, a LOT of air movement...ALL of which tends to distort unless you have unlimited power, cone surface area
- Velodyne has feedback loops that run several thousand times a second to ensure it reduces distortion...I have read from reviewers, measurements and (for me most importantly) from industry professionals like owners of audio manufacturers with no affiliation...that it works
- All-in, my layman's takeaway is: to get 20hz is one thing...to get it undistorted, filling a room at a level consistent with where it needs to be to match the rest of the "full range speaker" is an entirely different matter
4. So with all of that in mind, I did some simple logic and math
- Go with respected designers...because once I choose a basic path...I 100% must trust the designer, because I have not really got a clue about what's good or great or not
- My basic path based on simple math (Name, #/Size of Cones, Cone Surface Area, Displacement (based on excursion)
| REL 25 - 6 Pack | | 6 x 15 inch | 1,060 | sq inches | 4,241 | inches cubed | |
| Funk Audio 18.2 x 2 | | 4 x 18 inch | 1,018 | sq inches | 3,054 | inches cubed | |
| REL 25 - 4 Pack | | 4 x 15 inch | 707 | sq inches | 2,827 | inches cubed | |
| Magico Qsub 18 x 2 | | 4 x 18 inch | 1,018 | sq inches | 2,708 | inches cubed | |
| Wilson Thor x 2 | | 4 x 15 inch | 707 | sq inches | 2,121 | inches cubed | |
| Funk Audio 18.2 x 1 | | 2 x 18 inch | 509 | sq inches | 1,527 | inches cubed | |
| Magico Qsub 18 | | 2 x 18 inch | 509 | sq inches | 1,354 | inches cubed | |
| Wilson Thor x 1 | | 2 x 15 inch | 353 | sq inches | 1,060 | inches cubed | |
| REL 25 x 1 | | 1 x 15 inch | 177 | sq inches | 707 | inches cubed | |
| Velodyne DD18+ x 1 | | 1 x 18 inch | 254 | sq inches | 662 | inches cubed | |
- As you can see a single Velodyne DD18+ which makes a meaningful improvement...pales in comparison to the REL 6-Pack in terms of physical displacement...not only can we confidently guess no amount of error correction is going to make the DD18+ outperform the sheer scale of the
REL 6-pack because the 6-pack is loafing to deliver the same amount of bass as the Velodyne (therefore highly likely lower distortion)...
...but once again, I come back to the first premise which is GO WITH A GREAT DESIGNER IN ALL CASES. 6xREL flagship vs 1x Velodyne flagship.
5. Finally we look at physical space/size and budget. The REL 6-pack is HUGE...a SINGLE column is 29 inches ACROSS and 31 inches DEEP and 64 inches tall...That is a LOT of floor space when you are then talking TWO of these columns over 5 feet high each.
- Then there is the cost...some 45K for the set
- Compare that with the no doubt awesome Wilson Thors which each cost 25K or more (50K)...plus amplification and crossover necessary...(12K-15k?)
- By contrast of ALL the options on this chart...the very next 'theoretical top performer' is the dual Funk 18.2...each of which is 24" x 24" x 22.7". Dual-opposed, an exceptional reputation by all account I have been able to find...and the measurements from 3 sources look outrageously clean.
- If you are playing these at probably UP TO 28hz-32hz...then we are talking about low-distortion air movement more than tunefulness (I think...conjecture on my part.)
Hence that is why I have Funk 18.2s in my sites...something to look at...but only after the system here is fully calibrated setup, and some next-up finetuning being done now.
