That will be very nice. I can remove HQ player all together!
Does hqplayer on the extreme play gapless?
Yes. but only if using it as a standalone player.Does hqplayer on the extreme play gapless?
Hi, a loyal customer of Taiko with the SGM EVO and other isolation products from them for a few years now, when will TAS be released to us … been waiting for months now … an update will be greatly appreciated, thanks
Hi Emile = That is truly a system to make one swoon! Had you heard the Extreme/Alsyvox combo with Aries Cerat before? I imagine it sounded pretty sweet!
Sounds dreamy, Emile, thanks for sharing your impressions!It sounded remarkably good for a “quick & dirty” show setup, significantly exceeded my expectations.
I have heard a similar setup before when I visited the Ultisone listening room a month ago. Obviously this performed at a much higher level then at the show, good power quality, a fully SMT treated room and the top model 2 chassis Kassandra DAC, the single chassis Helene we used at the show is the entry level model which is about half the price of the Extreme.
Gun to my head my impressions based on the above two encounters are Aries Cerat electronics excel in dynamics, speed, agility and, I guess unsurprising for tube gear, good midrange texture retrieval and plenty of air and space.
The Essentia monoblocks at 40 or 60 watts are surprisingly powerful aswell, they did not run out of steam on very high levels and stage big with an authority you only expect to hear from much higher powered amplifiers. Ofcourse the Alsyvox Botticellis are a relative easy load with a pretty much flat 4 ohm impedance with first order crossovers and a 94dB efficiency, but still the Essentias “sounded” much higher powered then what I would expect going strictly on their power rating, the room at the show was fairly large at 50m2 with 3.20m high celings, and quite lossy with 1 side mostly covered by windows and 1 thin wooden particle board wall….
Gorgeous looking setup, what a combination, and really nice to put some faces to names. Thanks for sharing the pics and so glad to see shows happening again!
Gasp! 22 Daiza platforms?and i have 22 Diaza's in my system. it seems very organic and life like.
Does anyone else hear any fan-like noises coming from their Extreme? I don’t recall hearing it before. The attached video captures the noise pretty well.
That means you have the storage card fan enabled. You can disable it again by moving the dipswitch on the rear of the storage card to disable.
The support email address support@taikoaudio.com is still the correct address to use to request assistance?
