I have a upstairs room with 7' ceiling, 11' width, and 30' length. To insulate the ceiling, I had the existing drywall-fiberglass insulation removed, and had the roof rafters spray foamed with 5" of foam. New drywall, lots of vacuuming, and paint and now it's a cozy reading room and bedroom (for short people like me).
The odd thing is the Magnepan LRS speakers have amazing bass response. They sound just a good as my 1st floor Magnepan 0.7 with Martin Logan subs. They play rock, new age, movie soundtracks, what ever as loud you want. I'm guessing the drywall sloped ceiling (with closed cell spray foam), kneewall (1/4 drywall and 1/2 plaster), and solid floor (1" planks, 5/8" sheeting, 1/2 foam, and thick carpet) are acting like a "horn enclosure". The curved surfaces are plaster, of course.
The LRS are ~4' from the front wall, best listening is sitting ~3-4' from the back wall. Excellent sound stage, the room is very quiet, and the bass is very strong at very low sound levels.
Has anyone found this to occur with sloped ceiling rooms? It is just for low ceilings like mine?
