Audiophile power cords vs. the cables in your walls
thedudeabides
2,181
691
1,200
Alto, NM
Gotcha Gordon, but with all things 'wire' snake oil abounds !
Dave,
If you are interested in hearing what a more "expensive" pc can do within your budget constraints, you can buy through Music Direct and decide yourself if it's snake oil or the real thing. If snake oil, just return in 60 days for a full refund. If you don't want to put forth the minor effort to do this or are happy with what you have and have no interest of potentially improving the the sound of your system, works for me.
But I think it's an unfair generalization for you or anyone else to categorize (and criticize) all more expensive "after market" cables as snake oil until you've auditioned them in your system. I believe your position is probably based on personal bias / speculation and not necessarily reality my friend.
As I stated above, I thought the top Pangea PC was an affordable product that would produce positive improvements but after comparing with my Shunyata, it's simply wasn't true. And by a large, easily audible margin.
Best,
Gordon
Reactions: christoph
DaveC
3,899
2,142
495
Dave,
Best,
Gordon
And if you'd like to try something significantly better than Shunyata I'll send you cables to try for free. :)
thedudeabides
2,181
691
1,200
Alto, NM
How can you turn down an offer like that Dave? Kudos to Dave C. for his confidence in his product.
And Dave C., I'd like to try your wire but I'm at the end of my audio journey and happy where I landed. Time to call it good enough for me.
Reactions: christoph and DaveC
twitch
602
247
1,605
SE Pa
I went on your website, where's the info on the $300 PC you're talking about ?
DaveC
3,899
2,142
495
I think I could do a better job with marketing them, but the lack of sales of my entry level cables has been an issue for many, many years. Believe me, I try to offer a good cable for prices most can afford.
POWER CABLES
Clear Bass Power Cables are made using wire of excessive gauge for the application to ensure the fastest possible instantaneous current delivery. All three legs of the power cable are 9 gauge. The plugs used are genuine Furutech FI-15+ with copper contacts and rhodium plating.
These are fantastic power cables and I think some folks will prefer them over any pure copper cable, because they add less warmth, allowing the spatial cues to form a more immersive soundstage and the fine detail to produce a more realistic timbre. Out of the entire Clear Bass cable lineup these are exceptional cables for full-range use as well as subwoofer use.
These are very flexible cables that are thin and easy to handle.
Pricing is $299 for 1 meter length and $75/meter for additional length.
Stereophonic
891
674
410
Spain
The manual of the Schiit Yggdrasil DAC, version 1, states in the list of DAC connections:
9 Power Cord.
Plug the end of the supplied IEC cord in here. You can also use fancy audiophile types, but they won’t really do anything—what about the thousands of feet of crap copper cables in your walls, huh?
(End quote.)
What say ye? What would be an argument against such technical reasoning?
I only find an option after reading that…
Close the manual. Get it back to the box with the Dac, return it to your dealer and keep this brand far from you….
“You can also use fancy audiophile Dacs, but they won’t really do anything—what about the difference if digital signal is only 1 and 0?”
:cool:
tony22
591
259
153
63
DaveC
3,899
2,142
495
:cool:
I empathize with your sentiment, but I'm probably going to buy a Yggy eventually! :)
Hi Dave. Can this be made with a 20A IEC?
Sure!
Al M.
8,805
4,551
1,213
Greater Boston
Reactions: DaveC
tony22
591
259
153
63
Thanks Dave!
twitch
602
247
1,605
SE Pa
Agreed, less 'verbal fluff'
POWER CABLES
basic principles of Ohm's Law
So if they are not made from copper, what then? and if cooper adds warmth how does one account for the miles of cable that precedes it ? Regardless, your copper claim is a first for me !
Sorry, this is much more in line with ones speaker choice and room integration
thedudeabides
2,181
691
1,200
Alto, NM
Dave,
Just try the damn PC my friend. Yes it's hype. Nothing unusual about that. Common industry practice. Sounds like may be reluctant (afraid?) to take Dave C. up on his very generous offer. I, for one, am very interested in your comments. You have nothing to lose except a few hours of your time. Be well.
Gordon
Reactions: DaveC and christoph
Billinge
28
21
3
61
Following up from my previous posts I found the following interesting info...
definition: What’s The Difference Between Linear And Non-Linear Loads?
AC electrical loads are referred to either as linear or non-linear depending on how they draw current from the mains power supply waveform.
With a linear load, the relationship between the voltage and current waveforms are sinusoidal and the current at any time is proportional to the voltage (Ohm’s law). Examples of linear loads would include transformers, motors and capacitors.
On the other hand, with a non-linear load the current isn’t proportional to the voltage and it fluctuates based on the alternating load impedance.
Common examples of non-linear loads include rectifiers, variable-speed drives and electronic devices such as computers, printers, TVs, servers and telecoms systems that use switched-mode power supply (SMPS) power conversion technologies. They are also typically found with blade servers.
Having identified what we mean please see the following respected engineering article (no audio vendors here :) )
How bad harmonics influence the work of motors and generators, transformers, capacitors etc
The distortion in the waveform in the load current of any nonlinear device causes similar changes in the voltage waveform relative to the harmonic impedance of the source network. This voltage distortion affects both the current and voltage for all other loads connected to that system.
Effects of Harmonics​
How bad harmonics influence on motors and generators, transformers, capacitors and other equipment (on photo: FLUKE 437-II testing equipment power quality tool)
The common effects of such harmonic distortion are as follows:
  1. Motors and generators
  2. Transformers
  3. Capacitors
  4. Power cables
  5. Electronic equipment
  6. Switchgear and relaying
  7. Fuses
  8. Communication Systems Interference
4. Power cables​
Power cables are inherently capacitive and, as noted above for capacitor banks, their capacitance can produce a risk of resonance with the inductive parts of the network.
These resonance risks and the harmonics themselves can produce the following problems for cable systems:
  1. Cables involved in system resonance may be subjected to voltage stress and corona.
  2. Increased heating due to higher rms current, skin effect, and proximity effect. The skin effect will vary with the frequency and conductor size.
Power cable conductors commonly lie very close to one another, and therefore the high-frequency currents in the outer skin of one conductor influence the spread and behavior of high-frequency currents in the skin of the adjoining conductors, giving rise to a “proximity effect.”
The skin effect and proximity effect are proportional to the square of a frequency. Cables therefore have to be derated if there is significant harmonic distortion, particularly if ITHD is greater than 10%.
Of course our engineering colleagues with many years experience will say, as engineers we fix all problems, but in reality we know that nearly all products are a compromise based on cost, tolerances, less than perfect specs and good enough
So everything is by degree, and given we are looking for as close to 100% perfection not 90%, 95% etc, it is not unreasonable to believe power cables affect audio and visual equipment, true a $100k amp may deal with crap better than a $2 or 3k amp (or cd, 4k player or tv).
PS - re: Use shielded cables for equipment rated above 600 V.
Even my Panasonic tv came with a hardwired 300-500v mains lead and a audio fuse!
myself
5
2
85
10 years ago I have upgraded the in-wall(50feet total) power cord (running from the fuse box to hifi) to Cardas Functional Perfect solid core pure copper inwall (3x 10 awg). After running in, there’s a great improvement over the pre installation. During that time, I was using Tara lab the one, siltech ruby mountain 2, and argent flow Olympic for PC.
if I were better off financially, I wish to upgrade the inwall again.
Reactions: Addicted to hifi
Addicted to hifi
4,610
2,039
265
52
Australia
Thats what I need to do to our house as it’s quite old.
Al M.
8,805
4,551
1,213
Greater Boston
Recently I also changed my in-wall cable from the fuse box (42 feet) from 12 AWG to 10 AWG (shielded MC 10/2 cable). Big difference, less distortion, tighter bass.
Fuse box is new too, needed to pass inspection for my new solar installation.
Will also (gasp) upgrade to audiophile power cables that I have on audition right now.
myself
5
2
85
Don’t forget the fuse! the size is small but the impact is great.
Al M.
8,805
4,551
1,213
Greater Boston
Sure, I'll buy a bunch of these:
https://www.whatsbestforum.com/threads/who’s-up-for-a-2800-fuse.32202/
PeterA
12,669
10,942
3,515
USA
Al, do you mean breaker box? Or do you really still have fuses?
Al M.
8,805
4,551
1,213
Greater Boston
Sure, breaker box. I must have adopted the nomenclature of the post that I replied to.
Reactions: PeterA
