Hi Lagonda.I am impressed that Wadax uses a cable that in it's standard version cost over £600, customized version is most likely even more, ! If all parts are of similar high/expensive quality it would be one of the explanations for the high cost of their products.
Interconnects are one of the keys to reach optimal component level.
I’m currently using Siltech Universal Crown USB cable from Atlantis Server to Atlantis Dac.
It is a very expensive cable but your system will be always as good as the worst component it has. Worst from synergy perspective. Money doesn’t assure you best synergy.
From my point of view, Akasa cable is a bargain. Every Ref. Dac user reports that optical connection betters USB one by a wide margin.
And it is logical.
There are good Dac designs and Servers too but one of the key of Wadax success is that they are designers of both Dacs and Servers.
So they can match their technology in both components with a clear final point and best synergy between them.
I asked about to implement its proprietary optical hardware on my Atlantis but it isn’t possible.
The hardware fiber box is bigger than half Atlantis volume.
You can see it inside right flight case.
