Technics SP10 MK3 Restoration
rich121
100
41
133
Washington State
Just got my SP10 MK3 base (motor unit & controller) back from JP at FidelisAnalog.com
JP is one of the most knowledgeable on the SP10 MK3 and is the one who designed and manufactures the MN6042 Speed Control chip that keeps these and other Technics turntable models still operating.
My SP10 MK3 came with the stock Technics SH-10B5 faux obsidian base.
It has very low hours of use , no signs of wear at all on the bearing and not a single blemish, other than some specs of dust and a couple spots on the copper part of the platter that need cleaning.
**** I would like to have a 2 arm, constrained layer plinth built and have the motor unit mounted 'naked'. I am presently searching for somewhat 'affordable' plinth builders and suggestions would be greatly appreciated.****
The work that JP did to both the motor unit and the controller:
1. Pre-refurbishment measurement to baseline the performance of the unit and to see if there are any underlying issues.
2. Cleaning of all PCBs to remove the factory conformal coating. At~40 years this coating tends to become hygroscopic which can cause stability issues.
3. Physical inspection of all solder joints under an inspection microscope. Many of the joints will exhibit annular deformities which can lead to joint fractures down the road. These must be cleared of the factory solder and re-soldered. There will also be poor joints that need the same treatment. You can’t just reflow as the solder alloys aren’t the same which can also cause joint failure down the road.
4. Electrolytic cap replacement and rectifier diode replacement.
5. Disassembly and cleaning of the motor. Bearing inspection and service work. Proper Anderol 465 oil is used for reassembly. Motor is then checked for any areas of bearing drag.
6. The brake solenoids typically needs cleaned, and band tension is adjusted.
7. Stop/start and speed selection switches in the motor chassis are measured for contact resistance. Too high of resistance is indicative of a switch failure in the future. In the control unit I typically replace all the tactile switches, and the start/stop switch if needed.
8. Relocation of the brake regulator transistor to the heatsink to prevent overheating of the board (factory design flaw).
9. MN6042 replacement installation.
10. PSU ripple check at all critical stages (10).
11. Course calibration is performed and post-refurb baseline measurements for FG spectrum, motor drive phases, etc. are taken.
12. After 48-hour run-in final calibrations and verification measurements are performed.
The basic service returns the unit to factory or better specifications (assuming no permanent bearing damage has occurred). This service is quite exhaustive and very different from the typical work I see of just swapping some caps out, checking some voltages, and adjusting phase tracking.
The advanced service adds on top of the basic service:
1. Replace all polyester capacitors.
2. Replace drive circuit metal oxide resistors.
3. Replace all voltage regulator ICs and update circuits.
4. Replacement of certain diodes.
Rick
wbass
177
95
93
44
Did you also get the top of the chassis refinished? I like the coppery look.
FWIW, my (more) affordable SP10mk2 plinth came from Acoustand in the UK. Lee was good to deal with, patient, flexible. He might be a little backed up, but I'd imagine many places will be.
rich121
100
41
133
Washington State
That is just something weird with the lighting, interaction with the copper color on the platter...has the stock chrome? finish.
Should have mentioned I'm in the US and I believe I already checked with Acoustand and they don't accommodate a 'naked' type plinth.
thedudeabides
2,192
708
1,200
Alto, NM
Do you like how it sounds without any further mods?
rich121
100
41
133
Washington State
Haven't mounted it to the original Technics plinth. I want to get a 2 - arm custom made plinth and will probably wait until then to set it up.
Addicted to hifi
4,610
2,039
265
52
Australia
but I would like to have a 2 arm, constrained layer plinth built and have the motor unit mounted 'naked'. I am presently searching for somewhat 'affordable' plinth builders and suggestions would be greatly appreciated.
Rick
Great stuff and news.enjoy.
XV-1
3,618
2,629
1,860
Sydney
After a long wait my Technics SP10 mk3 has a set of new clothes. New plinth made by Acoustand based in the UK. Extremely impressed with the bullet proof packaging, the quality of the plinth and attention to detail.
Tango
4,938
6,269
950
Bangkok
That's beautiful Shane. How different d0 they sound.
XV-1
3,618
2,629
1,860
Sydney
Hi Tang
the Technics obsidian plinth criticism seems to revolve around a slight leaness and grayness in sound - Can't say I totally agree, but overall lean and mean is probably an apt general description.
The new Acoustand plinth has deeper bass which seems to free up some more musical transparency in the mid range, including more realistic vocals and a more organic sound. stage depth and 3d space feels better - one thing my big belt drive does well.
For some reason I feel that the noise floor has been lowered and the backgrounds quieter - not sure if that is my imagination or not :)
All the SP10 mk3 strengths of speed, tape like continuity, bass control and ease of use remain.
Pretty happy so far. Even this wife has given her tick of approval over the more attractive looks.
Reactions: rich121 and Tango
rich121
100
41
133
Washington State
Hi Tang
Very impressive plinth!
Reactions: XV-1
XV-1
3,618
2,629
1,860
Sydney
rich121
100
41
133
Washington State
What plinth did you end up with your SP10 Mk3?
I haven't decided yet. Not working at the moment and using my MKII.
Yours is very nice. I bet a new arm board is expensive!
Reactions: XV-1
ferrari275
69
22
75
United States
XV-1
Ages ago I had the Obsidian plinth in the main system and the character I would describe was thin, drab and dull.
Btw, the new Acoustand Plinth and Sp10MkIII setup look really great. Congrats!
Reactions: XV-1
