Technics SP10 MK3 Restoration
rich121
102
43
133
Washington State
Just got my SP10 MK3 base (motor unit & controller) back from JP at FidelisAnalog.com
JP is one of the most knowledgeable on the SP10 MK3 and is the one who designed and manufactures the MN6042 Speed Control chip that keeps these and other Technics turntable models still operating.
My SP10 MK3 came with the stock Technics SH-10B5 faux obsidian base.
It has very low hours of use , no signs of wear at all on the bearing and not a single blemish, other than some specs of dust and a couple spots on the copper part of the platter that need cleaning.
**** I would like to have a 2 arm, constrained layer plinth built and have the motor unit mounted 'naked'. I am presently searching for somewhat 'affordable' plinth builders and suggestions would be greatly appreciated.****
The work that JP did to both the motor unit and the controller:
1. Pre-refurbishment measurement to baseline the performance of the unit and to see if there are any underlying issues.
2. Cleaning of all PCBs to remove the factory conformal coating. At~40 years this coating tends to become hygroscopic which can cause stability issues.
3. Physical inspection of all solder joints under an inspection microscope. Many of the joints will exhibit annular deformities which can lead to joint fractures down the road. These must be cleared of the factory solder and re-soldered. There will also be poor joints that need the same treatment. You can’t just reflow as the solder alloys aren’t the same which can also cause joint failure down the road.
4. Electrolytic cap replacement and rectifier diode replacement.
5. Disassembly and cleaning of the motor. Bearing inspection and service work. Proper Anderol 465 oil is used for reassembly. Motor is then checked for any areas of bearing drag.
6. The brake solenoids typically needs cleaned, and band tension is adjusted.
7. Stop/start and speed selection switches in the motor chassis are measured for contact resistance. Too high of resistance is indicative of a switch failure in the future. In the control unit I typically replace all the tactile switches, and the start/stop switch if needed.
8. Relocation of the brake regulator transistor to the heatsink to prevent overheating of the board (factory design flaw).
9. MN6042 replacement installation.
10. PSU ripple check at all critical stages (10).
11. Course calibration is performed and post-refurb baseline measurements for FG spectrum, motor drive phases, etc. are taken.
12. After 48-hour run-in final calibrations and verification measurements are performed.
The basic service returns the unit to factory or better specifications (assuming no permanent bearing damage has occurred). This service is quite exhaustive and very different from the typical work I see of just swapping some caps out, checking some voltages, and adjusting phase tracking.
The advanced service adds on top of the basic service:
1. Replace all polyester capacitors.
2. Replace drive circuit metal oxide resistors.
3. Replace all voltage regulator ICs and update circuits.
4. Replacement of certain diodes.
Rick
Did you also get the top of the chassis refinished? I like the coppery look.
FWIW, my (more) affordable SP10mk2 plinth came from Acoustand in the UK. Lee was good to deal with, patient, flexible. He might be a little backed up, but I'd imagine many places will be.
That is just something weird with the lighting, interaction with the copper color on the platter...has the stock chrome? finish.
Should have mentioned I'm in the US and I believe I already checked with Acoustand and they don't accommodate a 'naked' type plinth.
Do you like how it sounds without any further mods?
Haven't mounted it to the original Technics plinth. I want to get a 2 - arm custom made plinth and will probably wait until then to set it up.
but I would like to have a 2 arm, constrained layer plinth built and have the motor unit mounted 'naked'. I am presently searching for somewhat 'affordable' plinth builders and suggestions would be greatly appreciated.
Rick
Great stuff and news.enjoy.
After a long wait my Technics SP10 mk3 has a set of new clothes. New plinth made by Acoustand based in the UK. Extremely impressed with the bullet proof packaging, the quality of the plinth and attention to detail.
Very Very nice.
That's beautiful Shane. How different d0 they sound.
Hi Tang
the Technics obsidian plinth criticism seems to revolve around a slight leaness and grayness in sound - Can't say I totally agree, but overall lean and mean is probably an apt general description.
The new Acoustand plinth has deeper bass which seems to free up some more musical transparency in the mid range, including more realistic vocals and a more organic sound. stage depth and 3d space feels better - one thing my big belt drive does well.
For some reason I feel that the noise floor has been lowered and the backgrounds quieter - not sure if that is my imagination or not :)
All the SP10 mk3 strengths of speed, tape like continuity, bass control and ease of use remain.
Pretty happy so far. Even this wife has given her tick of approval over the more attractive looks.
Reactions: rich121 and Tango
Hi Tang
Very impressive plinth!
Reactions: XV-1
What plinth did you end up with your SP10 Mk3?
I haven't decided yet. Not working at the moment and using my MKII.
Yours is very nice. I bet a new arm board is expensive!
Reactions: XV-1
XV-1
Ages ago I had the Obsidian plinth in the main system and the character I would describe was thin, drab and dull.
Btw, the new Acoustand Plinth and Sp10MkIII setup look really great. Congrats!
Reactions: XV-1
Hi everyone, I am looking for a company who is able to complete a full service of my SP10 MK3 in Europe mainland. Any advices?
my advice would be to contact a local dealer in Europe for Richard Krebs Technics SP-10 upgrades. likely either that dealer will be doing such upgrades or know someone who could do it. the below linked website should get you headed in a good direction. not sure how current the info is.
good luck. i did enjoy my SP-10 Mk2 and Mk3.
Hi Mike, thanks for the advice. I already had looked up the Krebs Update website, however they only mention addresses in UK. I would like to avoid customs as I am located in France.
ok. your best bet then would be to reach out to Richard Krebs personally via his website and see if he has any other ideas. likely any serious SP-10 upgrader in continental Europe has some connection to him.
Now that Bill Thalmann has passed, no technician in the US has been approved to complete the Krebs upgrade. I tried contacting all the email addresses listed on the Krebs upgrade site including those listed for Europe and Great Britain. The only successful communication was with the info@krebsupgrade.com address.
I have in the last few days emailed with Richard Krebs about the MK3 upgrade. His son, who also does the upgrade and is located in Sweden, is spending the next few months with Richard/family in New Zealand. Richard has offered to me to send the parts to him there and they will complete the upgrade.
Though I'm waiting for a final communication from Richard, I plan to send the necessary parts to Richard in NZ to have him and his son complete the upgrade. I believe this is the only option available at this time for the Krebs MK3 upgrade.
