so what kind of speaker cable to you use in this setup?
it is NOS off of a long spool. I don’t know the brand name or how old it is.
Thanks for sharing these details, Peter. What did they do exactly for your top shelf then? Dowels or something?
My new rack (48"W x 20"D x 29"H) plus two amp stand platforms were delivered a couple of days ago. They are made of Sipo wood stained a dark mahogany. The top shelf is 3" thick, the two lower shelves are 2". I am in the process of grinding and polishing the 1" stainless plates to a pretty high standard. Note the reflection of the Vitavox in the amp stand. There are nine plates total. The rack weighs about 200 lbs. It will support seven steel plates weighing 600 lbs plus 400 lbs of gear. The 225 year old floor is reinforced with a steel column in the basement directly below each of the front legs. The rack is extremely strong and solid. Leveling on my uneven floor boards will be achieved with matching wood square/flat shims of varying thicknesses.
This rack and stands will fit in with the decor of the room. The rack is larger than my existing rack which I built for the Pass gear, but 2.5" shorter. I wanted a horizontal look, so it is low and wide. This needs more clearance for the Lamm tubes, so it has three shelves instead of four. I will set everything up next week when David visits.
It will be nice to regain some floor space and get the gear up off the floor and the temporary platforms on to a proper rack.
So, micro Seiki and lp2 on top, LL1.1 control units on 2 with power supplies on the bottom shelf?
David and I set it all up on the new rack this evening after listening to the old rack as a base line; not an easy task.
So what is the difference in sound comparing the Klipschorn and the Vitavox? They seem similar in design. Are they about the same size? Have you listened to the Klipschorn? Just curious as the Klipschorns are more accessible.
(...) I understand the important thing is to find the speakers in original untouched condition. One does not want a pair that have been modified or “improved“. They will not sound the same. (...)
Have you tried other listening positions besides the sofa?
Hi Tim,@PeterA, quite a dramatic transition from where you were a year ago. And you've documented it well both in words and with excellent photography. I suspect several (many?) of us stand in awe of what you accomplished - I do. Obviously you took great care in assembling each piece with an eye to the whole and good taste is reflected in the ambience of the room. Many details well thought through. You had a plan and made it happen.
And of course, kudos to David.
Hi Peter, Happy Sunday!Here are some more photos of the room as it is now configured. We removed the last acoustic treatment which was a towel over the glass in one of the cabinets and we put back the fireplace screen. Neither affected the overall sound. I will also be adding a low mahogany butler's table in front of the sofa. The room is becoming a living room again, though with a rather imposing stereo system. Fortunately, David does not think it needs audiophile acoustic treatments.
