Mep,
Did you really believe that all audiophiles who listened using SS devices would go to Hell?![]()
Nah, I figured they were already there.
Mep,
Tim,
Your point looses definition as you seem to separate power (an amplifier attribute) from the efficiency or sensitivity of the speaker. What do you refer to when you say "Low powered passive systems"? A 15 watt amplifier with a 86dB speaker ?
Headroom can be a very difficult property to debate. IMHO it is much more than clipping behavior.
Frantz, you needed to hear all of what I call "Markisms". Having spent 3 days with him I can attest that he is filled with these one liners
This now tracks my conversation with Orb on another thread: it's all about the quality of those watts. 20 good ones will trounce 100 so-so ones ...I think 100 watts is about minimum for speakers in the high 80s. And high efficiency speakers don't really solve the problem for me because most introduce a whole other set of things I don't like. I didn't say it was rational.
Tim
I think 100 watts is about minimum for speakers in the high 80s. (...)
Tim
Here we agree. I can not live with less than 100-150 of good watts for such speakers. It is one of the many reasons I envy Steve's Alexandria's - 95 dB!
Gary needs to jump in here and explain why speaker sensitivity isn’t quite what it’s cracked up to be in many cases. Sensitivity measurements are normally taken at 1kHz and not across the audio band and then averaged if I heard Gary correctly. I know that my speakers are rated at 92dB which is on the high side and which means they should be able to play with low powered amps quite well. They did sound fine with 100 watt tube amps. They sound great with 200 watts+ of SS power driving them. There is no doubt in my mind that my speakers (Def Tech BP7000SC) love power. Why? I suspect that the 92dB sensitivity specification is not true across the audio band and it really dips somewhere. And remember, these speakers have a built in 1800 watt amp to drive the subwoofer built in. And, the speakers are rated for a crazy 1000 watts of input power which seems very strange for a speaker with a sensitivity of 92dB.
LPs are no doubt here to stay, Chad is no dummy and me thinks he’ll profit well with the opening of QRP. For me it’s becoming harder and harder to justify $50 for a 45-rpm LP that’s an umpteenth reissue of some schlocky ‘70s rock album. much of the recorded output over the last 20-yrs is natively digital, especially classical music. To me the worst of both worlds are digital LPs. With SPARS codes now missing from all new releases I’ve just decided to cease buying any recent recordings on vinyl.
Sorry, I would have to put that in the category of a "prejudice", the point in fact can be very vigorously argued: there's plenty of room in 16 bits for audiophile quality, but less than top notch mastering and end user player capability can make one think otherwise ...I look at it this way...at least I'm getting 24 bit D/A (hopefully) making the LP stamper. With CD's, your getting downsampled (most likely) and dithered down to (bit-rate) 16 bits. The sound quality is taking a significant hit. This point cannot be argued, imho. Cheers and all the best !
Frank
