Can you give us more details on this design? Is it reproducible?The largest issue I have heard with non-ideal horns that my newer JMLC horns with rollback have solved is removing this last bit of distortion from vocals.(...)
Thanks - but I was not asking just for the horn, but for the complete speaker!
The Iwata 600 I have from Autotech have JMLC DNA in them as they have quite a bit of rollback to them. Sound great and essentially no coloration with the Beyma driver. The Radian with Be isn’t working out like I had hoped and I am thinking the horn and driver are somewhat mismatched.the aerodynamics of the JMLC profiles are suberb and there´s no honk or plunk or echo or any other misbehaviour....
I use full rollback profiles from JMLC270 and up...
TAD 4003 hp at 550 and bandpassed to 2002 at 6K in 2500 horn
Do you have posted more details on your DIY speakers in any other thread?the aerodynamics of the JMLC profiles are suberb and there´s no honk or plunk or echo or any other misbehaviour....
Interesting because the measurements for the Iwata 600 on the website with a B&C DE250 show pretty good results. My own measurements were quite ok as well. I will admit though that I prefer the sound of the 18 Sound XT1464 + Beyma CP755Ti but not by a large margin. There is probably a bit more resolution that I get from the Iwata + CP350Ti but there seems just to be more grunt and I can cross lower with the other horn/driver combo.in our search for the perfect horn/ driver combo we found that Autotech Iwata horn was rather colored and far from ideal measuringwise either...
like most radial and Iwata profiles this is caused by relation between dimensions in height and width that causes reflections and colorations...
HiAnyone heard this new horn from B&C?
https://bcspeakers.com/en/products/horn/1-4/0/ME464
Its pretty big and claims to go down to 300Hz.
It was designed to go with their coaxial compression drivers (sourced from BMS or their own design?)
DCX464 8Ω - Coaxials HF - B&C Speakers
www.bcspeakers.com
Quite interesting as a two-way option...
Hi
Yes, I have heard them, i am using them at work.
They can go down to 300Hz depending on the horn they are on and if a single suitable horn is used, one can use up to a 12 inch driver below it in the same horn and live under the K=1 limitation.
They designed the hf unit as well as the lower range driver and because the two sources are "so close" acoustically, they combine coherently and so it is easier (as in actually possible) to make a "good" mf/hf crossover with these VS the BMS coax.
The advantages these have over a typical 1.4 or 2 inch driver is excellent hf response and efficiency and the absence of an obvious breakup modes / chaotic behavior up high. The disadvantages are cost, the dispersion is driver exit size (1.4 inch) limited around 20K to under about 60 degrees (if that matters in ones use) and working out the crossover for the horn one is using, to make it "flat".
It's a cool driver.
Tom Danley
Danley Sound Labs
Do you still use something like a two-way JMLC system? If yes, is it the 425 or a bigger JMLC horn? If the 425 can you please describe the apparent 3D sound stage size, or is that something which varies mostly from recording to recording?the aerodynamics of the JMLC profiles are suberb and there´s no honk or plunk or echo or any other misbehaviour....I use full rollback profiles from JMLC270 and up...TAD 4003 hp at 550 and bandpassed to 2002 at 6K in 2500 horn
