ray-dude
107
364
150
54
...and since folks are sharing albums that blossom with this type of holographic reproduction:
Since a couple folks have asked in PM, the later 2 links are to some samplers from Todd Garfinkle at MA Recordings:
I think I own about 40 albums from Todd's catalog, and eventually I'm sure to own them all.
Minimal recording technique, stereo mic, no mixing.
If you're a sucker for that sense of musicians being in the room with you (which Extreme and now the USB card are best in the world at delivering), highly recommended.
The catalog itself is a graduate course in music, with Todd's own music sensibilities providing a through line connecting a very large variety of musicians and genres. The samplers linked above give a great (and very generous) intro to his catalog.
Skanda
246
292
133
what is the screwdriver needed in order to open the top chassis? gonna sort that out before my card ships :)
Rhapsody
3,475
6,569
2,535
Brooklyn NY
Rhapsody.Audio
It's a metric Allen key/wrench.
Reactions: Taiko Audio
austinpop
201
658
223
Austin, TX
I used a Torx T25. Not sure that’s the “official” size, but it works great.
you also use a small Phillips screw driver to tighten the board into the bay. My suggestion is to use a magnetic Phillips as the screw is very small and can easily drop into the depths of the Extreme innards
MarkusBarkus
1,017
1,675
258
66
...BTW: the report that some find it necessary to bend the copper a wee bit for proper insertion...combined with Emile's comment about test fitting each board before shipment suggests to me that the soft/malleable copper may bend that wee bit upon removal from the test fit process?
Perhaps, eye-balling the board before installation, looking for a straight, parellel board and tweaking that wee bit as needed, might be a helpful step in the process.
I am still awaiting the blessed arrival, so this is speculative on my part, but what I will do. Cheers...
Taiko Audio
4,315
13,475
1,925
The Netherlands
taikoaudio.com
I think the trick is in how you insert it, you can see Ted guiding the bracket from the outside with his finger in the video at 0:30 here:
The slightly larger bracket angle makes for a tighter fit once inserted.
wil
1,523
1,551
428
I've done a limited amount of listening with the new usb card in place, but so far, in my system, at this point in time, this particular addition has pushed the musicality of digital playback to a new level. I think it's an accumulation of advances, but this seems to be the one to really do it.
Beyond the audiophile particulars like resolution, soundstage and dynamics, I'm simply aware of musical flow and purity.
Sometimes I've been frustrated by computer audio and tempted just get a CD player. Not any more! Gratitude to Emile and Co for continuing the quest!
Rhapsody
3,475
6,569
2,535
Brooklyn NY
Rhapsody.Audio
150 hours in with the usb card-
DRAMATICALLY more air, openness and an uncompressed feeling, which enhances a GRAND holographic 3D effect, with every track you play vs at the 25 and 50 hour mark.
I didn't listen to TAS from the 50 hour mark until this morning at the 150 hour mark. I left Roon/RSC playing.
I was astonished after 12 hours of the usb card being inserted. Astonishment has now moved to dumbfounded.
GAME CHANGER/Paradigm Shift :cool:
Blackmorec
755
1,288
213
DRAMATICALLY more air, openness and an uncompressed feeling, which enhances GRAND holographic 3D effect, with every track you play vs at the 25 and 50 hour mark.
Hey Rhapsody,
Sounds great!
Next time you get some relaxed listening time, try this album
Camille OUI http://open.qobuz.com/album/5060525430213
Listen to track 10 -Fille a papa- with your eyes closed. https://open.qobuz.com/track/40020349
Let the track play for a minute or two then pay attention to your feet and what they’re resting on vs. what you’re hearing. What do you notice? Now, without opening your eyes, try to picture where you’re actually sitting within the soundscape your system is creating.
Rhapsody
3,475
6,569
2,535
Brooklyn NY
Rhapsody.Audio
Hey Rhapsody,
Sounds great!
The soundscape is room encompassing:)
Rhapsody
3,475
6,569
2,535
Brooklyn NY
Rhapsody.Audio
I'm actually MORE impressed with listening to old 70's albums like America, Joni Mitchell type albums than I am listening to mind blowing recordings.
Listening to old albums that I always loved the music and now hearing it like it is being presented is a true gift. Much more of an emotional connection vs the great recordings like Touch by Yello. Although those are fun to listen to as well. BUT going back through the library of fav's over the years will be a real treat over the next months and even years.
Color me grateful;)
matthias
1,261
557
213
Germany
Color me grateful;)
Yeah, the difference between music and sound.
Matt
jelt2359
241
255
133
39
Silly question- if I use an external hard disk, should I now use the previous USB port that was for dacs and is now vacated? Or stick to the ones that I had been using?
Taiko Audio
4,315
13,475
1,925
The Netherlands
taikoaudio.com
That port can be 2 times faster if the connected device supports it (max 10Gbps, the others are 5Gbps).
Reactions: oldmustang
