Thanks for sharing, nonesup.In principle, its configuration is correct. Probably Alex from Uptone can help, although I think that until January 4 is not "operational"
Sorry, saw this late. I have connected etheregen between CX and S30. So far I am happy with results. Will try other combinations too and see how they sound different or good.As indicated by Uptone CX- ER - SR
Have you compared the 2?I highly recommend both of those PSUs (LPS1.2 and JS-2).
Perfect!This has been a pretty inexpensive vertical stand for my EtherREGEN and available in Black, Silver or Gray, https://www.amazon.com/gp/product/B078HNGD92/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&psc=1
I have tried different combinations of etheregen in chain of CX (server) and S30 (streamer) as well as etheregen A > B side vs B > A side. Uptone mentioned to use it between CX and S30. But of all the combinations, the best I got was etheregen > CX > S30 and going from A > B side on etheregen. I am currently using the suppled power supply. Will try Keces P3 12V to etheregen soon and see how it helps (if at all).
If they saw the best results with A > A, then it does not make sense from the construction point of view. But having said that, I did try that too, and system was very bright. I hope uptone can pitch in here to clarify, if A > A has any benefits.Did you try staying on the A-side only as well?
Experiences from the Taiko thread showed that going from A to A sounds best.
Matt
That’s because Extreme owners decided it’s best for them to use the ER as an FMC to feed fiber into the Startech card in their Extremes. The Extreme is a very different beast. Just because the ER’s moat didn’t benefit them, really has limited applicability to other servers. It certainly didn’t apply to mine.If they saw the best results with A > A, then it does not make sense from the construction point of view. But having said that, I did try that too, and system was very bright. I hope uptone can pitch in here to clarify, if A > A has any benefits.
I have heard Farad with ER. Worthwhile upgrade . The supplied SMPS is not comparableI have tried different combinations of etheregen in chain of CX (server) and S30 (streamer) as well as etheregen A > B side vs B > A side. Uptone mentioned to use it between CX and S30. But of all the combinations, the best I got was etheregen > CX > S30 and going from A > B side on etheregen. I am currently using the suppled power supply. Will try Keces P3 12V to etheregen soon and see how it helps (if at all).
