matthias
1,265
557
213
Germany
I think in my setup, I'm more simply trying to compare with or without the Melco switch:
1. Router > lan > OM > FO (70') > eRegen > lan > Melco > EXT
2. Router> lan > OM > FO > EXT
The eRegen in option 2 functions only as another FMC so that the Melco can be in the chain.
I could, however, switch up the FMC set up and put the eRegen first and the OM second.
Wil,
what is the reason for all these conversions from copper to fiber and fiber to copper in your set-up?
1. OM copper to fiber
2. ER fiber to copper
3. Melco copper to fiber
4. EXT fiber to copper
Sorry, I do not understand it. If you want a FMC only the OM is certainly the best device.
As I understand Emile it might be an SQ advantage to feed the Extreme with fiber.
However, in my view it does not make sense to have multiple conversions.
Best
Matt
wil
1,523
1,551
428
Wil,
Sorry, I do not understand it. If you want a FMC only the OM is the certainly the best device.
As I understand Emile it might be an advantage to feed the Extreme with fiber.
In my view it does not make sense to have multiple conversions.
Best
Matt
I does seem overly complex, and I'm hoping the straight OM > fiber > EXT option will end up sounding as good or better!
The reason for all the conversions is to allow for three things:
1. to use fiber for the 70' distance from modem/router to the audio system
2. to insert the Melco into the chain
3. to use fiber in the last leg to the EXT
If the Melco could take fiber in and fiber out, it would eliminate the need for two conversions. The Melco does have two SFP ports, but I've never been able to get them to work fiber in > fiber out. Which is frustrating...
Thanks, Will
matthias
1,265
557
213
Germany
Hopefully, good luck :)
Matt
MarkusBarkus
1,017
1,675
258
66
I am only a week into my Extreme project, but am using fiber into the Extreme to good effect, so far.
In my case, I have both an OM and PFBuffalo switch in the chain, and fiber into the home.
This network is 100% dedicated to audio. Everything else on copper from a different ISP.
It's too early to be swapping around gear, but my testing will be: OM vs. PFBuffalo. It would probably bring tears to remove that PFB...
Reactions: wil
dminches
3,486
2,860
1,410
Has anyone had issues with TAS where the music stops playing and won’t restart unless you clear the queue and re-add music? This happens to me pretty often, especially if I have over 20 songs in the queue. It won’t restart even if I hit the play button either on the “playing” page or in the queue.
oldmustang
1,072
3,177
1,445
I've found from time to time it's helpful to either turn off and restart the mode of TAS I'm using or sometimes completely shutdown and restart the app when I'm having weirdness with the queue.
I haven't experienced the same problem you describe, but I have experienced things like adding a track to the queue and finding two line items in the queue for that track, or most recently finding that streaming selections appear to be loading but never play, either sequentially as the next item up, or when hitting the Play icon for a streaming track.
A restart of the player has cured both problems so far.
Steve Z
dminches
3,486
2,860
1,410
Steve Z
What is the best way to restart the player?
Do you ever have 2-3 hours of music in your queue at one time? Just trying to understand how you use TAS.
cat6man
913
1,050
1,185
west of NYC, east of SF
i found odd things with over 20 in the queue if i was using gapless/batch.
this is a known beta limitation for batch/gapless.
i think (?) i had to change players (gapless-->serial) to fix it, but i'm not positive about that.
i don't see any of those problems with serial playback and queues of over >100 tracks/11 hours.
dminches
3,486
2,860
1,410
there is a known beta limitation for batch/gapless.
i think (?) i had to change players (gapless-->serial) to fix it, but i'm not about that.
Thanks, good to know. Frankly, I just want to make sure the issue isn’t just with my setup.
Right now I am running the Extreme all day to break it in which is why I am adding a lot of tracks. Sounds like I should just use serial play.
seatrope
210
300
178
I have predominantly used serial and not batch play, and have never experienced what you described David.
Reactions: dminches
oldmustang
1,072
3,177
1,445
I can't tell you what the best way to restart the player is, but here is what I do --
1. Tap the "System Settings" icon (page 20, TAS Manual v1.1)
2. On the System Settings page, the current mode of operation (direct, batch, HQPlayer) will have its little slider switch icon showing green with the slider to the right. Slide the switch to the left to turn off that mode.
3. After the player is off, slide the selector switch icon back the right again to turn on that mode.
Lower down on the same window, you can also select between TAS and Roon, however my understanding it this doesn't actually turn off TAS, which remains active in the background.
Finally, the bottom item on the System Settings page is "Restart Extreme" which will reboot the Extreme.
Reactions: dminches
seatrope
210
300
178
PS I kept the extreme playing nonstop with serial play to burn it in. I had a bill Evans album playing and 5 days later it was still going (had a bad work week so coukdnt listen at all).
dminches
3,486
2,860
1,410
I am listening to “Everybody Dig Bill Evans” as I type...
dminches
3,486
2,860
1,410
Love that. But I love Toots Thielemans as well, so it was “Affinity” that was playing for 5 days :)
My “best’ Bill Evans is my “Waltz for Debby” reel.
I am only 5 days into the process so I know I have a ways to go.
oldmustang
1,072
3,177
1,445
There is a little icon shown on page 6 of the TAS manual for repeat which will keep keep either the current selection or the whole queue playing continuously which might better serve your needs, though I haven't had a need to limit the number of selections in my queue in Direct mode.
dminches
3,486
2,860
1,410
Yea, repeat really is what I should be doing.
Reading the entire manual would help also but it sounds like changes are in store...
cat6man
913
1,050
1,185
my 11 hour playlist includes all resolutions and pcm/dsd, so i get to exercise all 24 bits to my totalDAC :)
wouldn't want the first 16 bits burned in and not the last 8 lsb, right?:p
EuroDriver
927
2,486
450
Monaco
Don't clear the Queue while the music is playing.
This is a known to break the command interface and will be fixed in the second Beta release
Reactions: ctydwn
I have been asked by several Extreme owners where best to place the Center Stage 1.5 footers under the Extreme
I found that the 1.5's work best when placed inside the stock feet but the two in the front are pushed forward and the two in the rear are pushed back so that they sit just under the edge of the Extreme
Here are a few photos that I attached in a different thread
Reactions: micky22
