Venus 2 arrived in Salt Lake City just 3 1/2 days after shipping from China. A new record in shipping time for my Denafrips purchases!
I hooked up all my digital cables (HDMI, Toslink and spdif) between the Venus 2 and Iris. After I burn in the Venus I will start switching around to different inputs to see which digital input I prefer
Can you describe in what areas the IRIS improves the USB connection from the PC, and does the basic tonality change in any way ( if the sound was neutral to slightly lean prior, does the IRIS in anyway impact that?)....Venus 2 arrived in Salt Lake City just 3 1/2 days after shipping from China. A new record in shipping time for my Denafrips purchases!
I hooked up all my digital cables (HDMI, Toslink and spdif) between the Venus 2 and Iris. After I burn in the Venus I will start switching around to different inputs to see which digital input I prefer.View attachment 71937View attachment 71938
Thanks
very impressed with T plus + Gaia with my Field coil speakers. Best DAC so far....very very happy with it.
Some sound impression of Dac.
Roon and streaming through youtube. home made PC with fanless and Linear power supply.Nice videos.
Which software music player do use in your system?
Thanks
Matt
I understand that, but in the USA the Tambaqui is $11,500 vs. $6,700 for the Terminator Plus. Almost double the price. I can image people saying "Yes, the Tambaqui sounds better, but it's outside my budget, so I choose Terminator (Plus)". I'm looking for people having heard both.Hi Robert. You posted this question on a Denafrips product owners thread.
I have a TP and IRIS clocked and agree the USB is improved from an Innuos Statement as Blake describes. Clocking just brings clarity to another level, it seems to me noise is removed and the sound is further unmasked.The sound is a bit fuller and more fleshed-out, but the biggest enhancement is in clarity, resolution, holography/sound stage. It is not quite apples to apples though, since we are now comparing the performance of the USB input vs I2S via HDMI input to the DAC.
Thanks
Richard,Hi Jazz,
I find using Denafrips ddc depends on your usb source and you have to try to really know.
I had/have the allo usb bridge signature, nuprime omnia S1 and the Antipodes cx+ex stack and with both the Gaia and Hermes, sound quality improves with the allo and the Nuprime but with the Antipodes, sound quality is slightly veiled with loss in dynamics.
Now with Uptone etherRegen for notable sound quality improvement, the Antipodes remains directly connected to the TP even more so.
Cheers.
Richard
Richard,
How does the TP connect directly with the Etherregen, there is no ethernet input though I wish there was?
I have an Etherregen between an Antipodes Core and Innous Statement then the Statements USB goes to an Iris and then HMDI to the TP.
In my system even though the Statement has an excellent USB the TP sounds better with the I2S input over the direct USB, and way better with the clock in on the Iris.
The Denafrips manual suggests I2S is the superior input for the TP.
I also wish I could output ethernet to the TP also.Hi Rikki,
Sorry for being not clear ....
The EtherRegen is before the cx as server only which is direct via ethernet to the ex as player only and then via usb to TP .. ethernet input of the Antipodes is not in same level of specialised EtherRegen and hence I find obvious improvement when it was added BEFORE the cx server.
Not familiar with the Innous Statement but guess similarly used as a player only and unless you have 2x EtherRegen and it is far from your Antipodes Core as server only, your single EtherRegen should be better before the Antipodes Core and not after which will then be too late to avoid detrimental ethernet effects which EtherRegen is for ?
I have the Avatar cdp and the Gaia/Hermes daisy chain clocked and switching to hdmi i2s via Gaia/Hermes into TP certainly sounded worse than switching to RJ45 i2s directly from Avatar .. less is best I believe but most importantly is what sounds the best to you. If your usb source is already excellent, I do not think it benefits from synced oxco clock of TP and i2s connection since it still have to change digital format and I will leave this directly into TP for also i2s to the R2R ladders within cm(s) on the pcba and not 0.5m i2s cable for the same "less is more".
End of the day, too many variables in all our systems to really know what will sound the best imho and our shared experience can only be for reference. For example, all say hard wiring ethernet cable can only be better than my dedicated wifi mesh to the Antipode cx which I am using now but my 25m supra cat 8 is up for sale as it sounded worse for my system to my ears ....
Cheers.
Richard
PS: i2s being better than usb in Denafrips manual may indeed be the case but since we are using usb source, it really does not apply for us ... you still need to convert in the ddc and would have been best if TP has ethernet digital input for my AntipodesView attachment 74943
Hi Rikki,I also wish I could output ethernet to the TP also.
I upgraded my HDMI to
AudioQuest Thunderbird 48 0.75m 8K-10K 48Gbps HDMI Cable (2.5ft)
and it made a HUGE improvement over
AudioQuest Coffee HDMI 1.5 m HDMI Black Cable HDMI – HDMI Cable (1.5 m, HDMI Type A (Standard), HDMI Type A (Standard), 3d, 10.2 Gbit/s, Black)
I also tried the Sommer HDMI recommended by Alvin, the Sommer was better than the Coffee but not in the league of the Thunderbird. I also upgraded my USB from a Curious Cable to
Network Acoustics ENO USB Cable Ag
and it was definitely better also, much smoother and detailed, airy.
I agree it sounds good to try less is more but my experience is the more I add the better it gets with the expection that I am on the fence about my experience with adding a master clock to the Etherregen and SFP fiber between it and a SOtM switch.
For i2s, I prefers RJ45 into TP in my system and not hdmi and for non dsd, you can also try dual AES-ebu from denafrips ddc to TP.
Cheers.
Richard
Hi Richard,
I liked RJ45 I2S as well, but, it proved to be very problematic running RJ45 from my Gaia to my TP (I think I wrote about the popping/static noises earlier in this thread). In order to avoid these noises you need an exceptionally short RJ45 to avoid these problems. I think Alvin suggested 30 mm or less if memory serves and physically connecting the DDC and DAC with this short of a cable in many situations will prove physically impossible due to the orientation of power cables for both devices and cables into the DDC.
Just from anecdotal evidence from reading various user reports, I do get a sense that a clear majority seem to find I2S to be sonically superior input over other inputs, but not everyone has the ability to run i2S into their DAC. Other than one or two users, I can't recall reading posts where a user tried all options and preferred another input (AudioBacon (Jay) prefers USB, but he details why in his Terminator review and it is due to his sonic preferences, rather than technical performance). Of course, the only opinion on this issue that matters is that of the user and frankly, all inputs sound really darn good on all Denafrips DAC's. Try it and find the one you like the best in terms of sonics.
