Thanks!This fuse is the protection of transformer located next to it. That transformer is the power supply for protection circuit.
Change the fuse? yes, I had a positive result, see also the guidance that the manufacturer recommends
hiAnother question Jon.
Did you replace the rectifier bridge (power part of the DMA150)?
I read a topic about Rectifier diodes cause ringing of the transformer.
Thanks Jon,
Yes, I saw that you used the RHRP860 as far as I can see.
But I actually meant the GBU806 rectifier
HiHi John,
Sorry but i do have another question and maybe you can give me an answer.
Does the transformer have more primary windings for input voltage?
220Vac - 230Vac - 240Vac
What lead you to discovering that? I have the same amp. Was it something you heard?my DMA150 S2 had two swollen capacitors.
I have seen the caps deformed on the top. really weren't any listening problems.What lead you to discovering that? I have the same amp. Was it something you
An unbelivable job you‘re doing.Chapeau!!! I am wondering what those 12 (13) transistors in the middle of your picture 10.jpg are doing?.....
Hi Jon,Thank´s ack
Dear ack
Let me ask you a question. From your experience, what is your reference / opinion about recommendation of fuse manufacturers in Spectral amplifiers?
jon
