Tung-Sol KT170
Marcus
614
743
1,155
“Due to the success of the KT120 and KT150 tubes and the popularity of these tubes with High-End Audio manufacturers, the Tung-Sol tube has been developed to provide a beam tetrode with even more power capability. The Tung-Sol KT170 has a power dissipation of 85 watts allowing amplifiers using a pair of these tubes to reach power output levels in excess of 300 watts.
The Tung-Sol KT170 has an original shape glass bulb that was designed specifically to maintain the highest vacuum and dissipate heat when the tube is operated at high power levels. The Tung-Sol KT170 also has an equipotential cathode for increased reliability and to effectively amplify audio frequencies in the output stages of High-End Audio equipment.
The Tung-Sol KT170 is the largest and most powerful tube in the 6550, KT88, KT90, KT120, and KT150 series of audio tubes.”
Reactions: CKKeung
Wow! I wonder how long until different amp maker's bless it for their systems. The KT150 was a nice upgrade when I used them in my ARC REF75 amp, I expect there will be others like me who'd like to pop these into my REF160M's to see if they offer a similar improvement. Certainly my Wilson Alexia (v1) are not shy if shown more power!
The guy with one post posted this, so weigh it as you will.
I heard that this tube is a JV between Tungsol and Primaluna via Upscale Audio. I heard this on the hifipodcast.net episode 10
Apparently Tungsol makes the Primaluna branded EL-34s that come with all Primalunas and this tube will be the most powerful tube that can be used on the Primalunas
Very cool looking. Pushes the design of the KT150s to another level
  • tung-sol-kt170-specs.pdf
Reactions: CKKeung
Whats with the redactions?
On Jadis' facebook :
I talked with Mike Sanders, Founder/owner of Quicksilver Audio about using these in my Quicksilver V4 mono amps, as they are the new model built around the KT150 tube.
Mike said he had tried using the KT170 in his 'Mono 120' amps that use a pair of KT150 tubes, but did not like the results.
Here is what he said about using in my V4 mono amps:
"We do have these tubes now and they do put out a lot of power but at much higher distortion than the KT150. They would
work in the V4 but would not sound as good as the KT150."
I'm hoping that the tubes he used were earlier versions and that they will have better versions later?
I tried the KT-170s on my Quicksilver V4 and Mike is right, more power but less fidelity. Overall, they sounded slow and muddy. I really don't think it's the tube's fault, but rather, Mike did not design or retune his amp around KT-170s.
Thank you for posting.
From what I have heard about this tube in the amps it does work with it is impressive.
Hopefully in the future it will be possible to have my V4s modified to use this tube.
Stunning tube. I love it.
A cursory glance under the hood of my ARC REF250 SE expunged the harbouring of any machinations toward a move on the 170’s, even though pretty certain of the headroom required of the power supply...There is simply not a Snowball in Hades chance of shoehorning those Fat Boys into the KT150’s socket array...
