Looks to also have a good phono pre includedTo be honest, I had dismissed the CL-1000 (on paper) because of no MUTE function and transformer-based volume control.... but if I get a chance to try it, I will!
According to this thread: https://www.audioaficionado.org/showthread.php?p=997830Looks to also have a good phono pre included
Yeap, it's a game room! (LOL)... But I'm not following what you mean by "wall mounts both end of the pool table"... Could you please illustrate a bit more?Looks like a game room so why not wall mounts both ends of the pool table? If you're looking for wow factor put an expensive painting on the 12' wall.
By end-game I assume you're talking about last attempt at the best level of musicality you can muster.I'm trying to put together my "end game" system.
To that end, I've got an M900u on order. and would like to get some feedback on speakers.
So far I'm considering Magico M3 (91dB, 4-ohms), and Focal Maestro Utopia EVO (93 dB, 8-ohms).
(I like them both but have not heard them in my room.).
My main concern is the space I have to work with... As shown, I've got sort of an L-shape room:
25-ft deep, but only 12-ft wide where the speakers would sit.
BTW, I'd d like to use a single M900u, so I need to consider reasonably efficient speakers.
Thanks!
S5 MkII?The M3s would sing in that room especially if you could put them firing out of the corner where the pool table is. The M3s are very, very good IMO.
Yes, the goal is a system I can enjoy and live with, and be done with "fiddling".... we're talkin' end-game playback system, right?
I realized that integrating what could be considered an "end game" system into a Game Room would be a tough challenge, if not impossible... I cut-pasted the Pool table into the room to make that point clear.The "long since known" was a nice touch. I tried that once but no one cottoned on
I had not considered Horns... Any specific suggestions? (Avantgarde Duos, perhaps?)In my opinion, narrow-pattern speakers (presumably horns or horn hybrids) make a lot of sense for your room.
The reason is, with speakers that have normal radiation pattern widths, a lot of significant early sidewall reflections are inevitable with the set-up shown. Quoting acoustician David Griesinger:
"The earlier a reflection arrives the more it contributes to masking the direct sound." And,
"When presence is lacking the earliest reflections are the most responsible."
And this is somewhat counter-intuitive, but many good horns will sound good throughout that room. They will produce a spectrally-correct reverberant field, so assuming the room isn't overdamped, timbre will hold up well even near the stairway where you're getting relatively little direct sound. To be fair Magicos are also very good at this; my point being that you're not necessarily giving up "good sound throughout the room" with more directional speakers.
Horn speakers tend to work better than most when close to the walls and/or in corners, so even though the enclosures would be larger than what you've drawn, you'll probably end up with a net gain in usable floor space. Also it's okay to put stuff on top of big rectangular horn boxes, whereas it's not okay to put stuff on top of Magicos.
And finally, good horns have an inherent kick-butted-ness that says, "Welcome to my pool hall".
I find the Cessaro Horn Acoustics Wagner II a really lovely "compact" horn loudspeaker, and I think it would be a great fit in your room.I had no considered Horns... Any specific suggestions? (Avantgarde Duos, perhaps?)
I've heard both the S5 Mk IIs and the M3s. They are both excellent with a similar sonic signature that's detailed without the older Magico's more sterile (for lack of a better descriptor) sound. The M3s will take you deeper into the music but the S5 Mk II is no slouch. Either are excellent IMO and with sealed bass should work well.S5 MkII?
Not that tough a challenge ...I realized that integrating what could be considered an "end game" system into a Game Room would be a tough challenge, if not impossible... I cut-pasted the Pool table into the room to make that point clear.
Hence my reason for coming here to get advice and ideas, so thank you all for that.
Thanks!
Lots to consider, thank you!My personal preference is more towards constant-directivity horns for your situation, which imo puts more of a premium on the off-axis sound. Ime the Avantgardes are more of a "sweet spot optimized" speaker than a "throughout the room" speaker.
What jumped to mind is the Classic Audio T-3, BUT I'm not sure that it's a particularly solid-state-friendly design, and the field-coil drivers complicate the setup because they need their own separate power supplies. That being said, you might contact John Wolff and see what he has to say. He can probably still make them without field coil drivers while including his other evolutionary improvements.
The JBL M-2 studio monitor is another possibility, though it calls for an external active crossover and multiple amplifiers, so again it's complicated.
However PBN makes a rather awesome passive variation on the M2 theme (using TWO 15's instead of just one) which they call the M2!5.
The discontinued JBL S9500 also come to mind, and there may be others from that generation as well.
In a bit lower price range, the JBL 4367. All of the JBLs will work well with solid state.
If you want modern art instead of a rectangular box, the hOrns Universum is kinda stunning, not sure about its compatibility with solid state. This is where I'd insert the Avantgarde Duos as well, again not sure about solid state.
Finally, at the risk of being overly self-serving, I have done custom speakers tailored to specific room situations and could do something which would work very well in your room, either snug in the corners or out a bit (your choice), but I'd want to provide you with a representative audition first because I'm pretty much an unknown.
My top recommendation would be the Classic Audio T3 IF John Wolff says it would work well in your situation. If not, then either the M2!5 or something custom by yours truly, or the hOrns Universum for speakers guaranteed to give you an unfair advantage in pool tournaments by distracting your opponents.
OK, since you're a dealer, may I ask: What are the minimum recommended distances:I find the Cessaro Horn Acoustics Wagner II a really lovely "compact" horn loudspeaker, and I think it would be a great fit in your room.
Full disclosure: please note that I'm a dealer for Cessaro.
Glad to hear it can be done in the real world"!Not that tough a challenge ... View attachment 71942
