I think it really depends on how determined someone is about this hobby, some people ends up with a pair Bluetooth speakers and are very happy; some people stops at B&O; as for someone like us...we never stop
Hi Lloyd ,Hey Arshad,
Hope all is well. Great stuff...do you use 3 or 4 of the Shun Mooks...is there 1 in the back or 3? I also notice you have placed a Receivus underneath...is that right?
Hi Lloyd ,
All good thanks. Congratulations on the K15EX , indeed a special pre amp. 3 Giants, Tripod ... 2 in the front , 1 at the back. Affirmative to the Receivus . Is the ground post still provided, does it respond to external grounding after the super ground update?
Sort, of i guess. I'll have a look at mine. Thanks.That is exactly what I originally thought...but if you put too much at the back...then ironically, with all the loading at the back...the entire front of the unit can simply just 'hang' in mid-air! Which means there is NO downward pressure on the feet in front. I would have thought when vibration goes through the component then, you dont have a particularly damped chassis.
In order to really get the unit to sit evenly and flat and also 'fully loaded' on all 3 feet, I found it better to put 2 on the front and only 1 on the back so that more of the weight 'falls forward' over the front 2 footers. Hope that makes sense.
Hi Howiebrou,Sort, of i guess. I'll have a look at mine. Thanks.
Thanks Lloyd. You are a most meticulous beast. I think I would get a hernia before I could discern the weight distribution patterns of a preamp.Hi Howiebrou,
FWIW, I placed the left front HRS coupler behind the Koda footer and slightly to the outer edge of the unit. The right front HRS coupler sits behind the Koda footer but on the INSIDE edge directly under the volume knob (eg, sitting directly underneath the volume control mechanics).
The BACK HRS Coupler sits on the back edge of the unit flush...but slightly off the RIGHT by about 3cm-4cm. When I placed it dead center in the middle, I found that again, I got an ever-so-slight weakening of the signal...extremely subtle. I was trying to figure out if it was weight distribution again...in the end, I stopped trying to be a scientist and put it back off-center, and it has been great.
Double stack them? Whenever I use Stillpoints Ultras...I use HRS Nimbus Couplers with them. I do not use the Stillpoints/HRS Nimbus Coupler combination with Koda because we have the HRS M3X shelf already.Anyway in these days I did some tests with a very strange result. If I use harmonix TU666M it loses body and gains in resolution. If I use harmonix TU999m (which I should not use as support) I recover body and I lose resolution.
I think the manufacturers of our toys do it on purpose to keep us busy....![]()
Why does a 60K pre amp even need footers?
No idea if you can double stack Harmonix or if it would even work.
Very interesting! Yes, as you can see above, I do same...HRS Nimbus with Stillpoint Ultras.I do it on HRS M3x bases. Using Aavik Pulsarpoints plus Harmonix. sometimes the way to go...
To get the energy from a component away, it is preferable to have only one point of energy coupling and 2 points of decoupling.
I prefer combining one Pulsar Point / Stillpoint with two more soft feet like HRS Nimbus or sometimes wood,
like Cardas myrtle wood. Did it with my former Koda 10 preamp.
Hi Guys
Can I find out what you got with your k15ex; how was it packed in the box and what documents came with it? This is what I got today from the distributor and it really shocked me!! A few photocopied pages and the preamp just packed loose in what seems to be the original box for the K15ex as well. Is there a flight case that comes with it? Very concerned
Hi Guys
if i can swear....yes this is a bit crap......to put it midly. bugger....and this was from the distributor where i can only assume it is the factory packaging that it came in. thats crazy. I did confirm with the distributor that the unit will come with all the original documentation and packaging and he said yes...well if this is all there is i am sorely disappointed!
I was also told that the one i have has the grounding box upgrade installed in it as well - how can i tell if thats the case? Can;t see any photos online of the addition
