It is never too late for a happy childhoodOn this forum a lot of people have second childhood angst
You should give Phoebe Bridgers a listen.But seriously, Billie Eilish is great.
Awesome write up!
Your and Peter's observations/experiences constantly push me to question/experiment with my speaker positions.....
Congrats Al, it really looks great!The issue of positioning the subwoofers is an interesting one. JoeyGS was the first to ask the question on my system thread if the subs should not be more in front for better time alignment, next to the main speakers:
https://www.whatsbestforum.com/threads/my-monitor-subwoofer-system.25101/page-6
JL Audio themselves send contradictory messages about this.
On one hand their technical consultant said that because of group delay of modern sealed subwoofers (I suppose that means high-powered subs with heavy motors), including JL Audio subs, these subs would need to be put far in front of the main speakers. In the case of JL Audio, with group delay of 9 milliseconds, this would amount to 10.1 feet in front of the main speakers, see the WBF thread:
Subwoofers and Time Relationships
On the other hand, JL Audio's manual for my subwoofer(s) states preferential positioning in a corner or at a wall, and does not mention a preferred distance.
If you would follow their first line of argument, even positioning of the subs along the main speakers, as is often advocated for better time alignment, would theoretically be only somewhat more sufficient than what I had until now, with subwoofer drivers about 5.5 feet behind the main speakers -- compared to my solution thus far it would eliminate only about 1/3 of the problem, with almost 2/3 still to go. So in terms of timing, putting the subwoofers closer to the main speakers seems not the most compelling argument; if you really want to go all the way, you would have to move the subs closer to the listening seat rather than to the main speakers. -- JL Audio's CR-1 crossover can correct for the time delay of subwoofers relative to the main speakers.
Several WBF members have argued that time alignment is not critical at subwoofer frequencies, see this thread:
Time aligning subs to main speakers
I had long resisted a move of the subwoofers away from the front wall for several reasons, apart from the above contradictory messaging:
1) as audiophile friends have acknowledged, rhythm & timing of my system has been excellent
2) I found the bass on a lot of material very precise, also compared to other systems, except on one type of material (I'll get to that)
3) as much as I tried (and I did!), I have never been able to hear any time delay between main speakers and subs, e.g., on drums (kick drums and others), and neither have others whom I asked to listen for it
4) I knew that the ASC SubTraps, which my subwoofers stood upon, were hugely beneficial for the sound, and I hesitated moving the relatively high stack of SubTraps plus subwoofers closer to my main speakers because of an expected detrimental effect on soundstaging.
Yet the issue came up again from time to time, such as in the comment of Brad (Morricab) here, which I replied to further below on that thread page.
Ultimately I decided that it would be worthwhile trying to move the subwoofers upfront, but then only under one condition. I would not use the SubTraps since they would be in the way, but I would have to find somewhat of a substitute. I decided to put the subs onto concrete plates, as I also have them under my monitor stands. This would avoid direct coupling to my suspended wood floor, which I knew was disastrous, and if I used two plates instead of one (4 inches total thickness) it might raise them sufficiently from the ground as well, so that the subs would not excite the wood floor right in front of them too much.
Yet then the pandemic hit, and I forgot about the project. After all, I did not have the concrete tiles necessary, and I was not going to go to Home Depot at that time (my health was too important to take the risk). Thankfully, a recent suggestion by Charles (Chops) on my thread reminded my again of the idea and so finally I went to work, now that in our state of Massachusetts the pandemic is much more under control. I bought four 16 x 16 inch concrete tiles at Home Depot for a whopping 17 bucks total, and then moved the subs together with Peter A. who had graciously agreed to help. With two persons, moving those heavy subs of 110 pounds each is actually easy, whereas JL Audio sternly warns against trying to do it alone, also because of the potential of back injuries.
The first spatial arrangement was this:
While there did not seem a sonic disconnect between subwoofers and main speakers, the bass did not seem quite right. It was less tight than before, and some frequencies, e.g., related to the impact of kick drum, were weaker. Another issue was that now -- something that I had not considered when planning this arrangement -- the main speakers would partially radiate onto the glossy surface of the subwoofers beneath them, possibly creating detrimental reflections. Peter suggested that we could get the subwoofers more out of the way of the main speakers by putting the subs next to the speakers. We could do this if we moved the main equipment rack further back.
In previous times I would have objected to a rack move because I did not want to get the equipment more in the direct fire of the sub bass, but since the subs were now in front, I welcomed the idea. So we moved the equipment rack 10 inches further back, also the amp rack, and moved the subs next to the speakers. The drivers now are about 4 inches in front of the main speaker drivers, and since they are closer to the listener, the measured sonic path to the ear is 6 inches shorter.
Now the bass was better than with the first arrangement with subs in front of the speakers, and in some ways I heard also better bass than with the subwoofers at the front wall. I'll get to that later.
Here is the new set-up (sorry about the whitish stripes in the pictures, they are reflections from the flash, cold not avoid it):
Hey Al, good to hear you finally tried moving those subs. And you got good results.
A couple questions:
1) Do you need to employ the JLAudio trim function to the same extent?
2) Does your current configuration improve cello in string quartets to your satisfaction?
I'm looking forward to hearing the results!
Awesome write up!
Great news Al. Congratulations.
I was going to ask the exact same question about cello that Ian asked. For me that is where a full range floorstanding speaker demonstrates its value.
Now for the really serious question: how does that Black Sabbath sound with the new subwoofer position and calibration?
What are you doing now that not telling?Yes, these things are contagious, lol.
Thanks for an interesting and cogent write-up Al, about changing your subwoofer positions and vibration traps. I think both you and Peter challenge us to do some work!
