Possible. I am referring to wiring them in parallel.
Mine are wired in series
CD sound high efficiency woofers / parallel wired 100 watts tube
With a standard Samsung A 70 .
No they are not the same the big woofer is 200 watts nominal and 8 ohms nominal
In series.
They hardly move doing this
Okay good ..Would be good if you could do a few more videos with mobile from listening position of other tracks
Okay good ..
But not today later this week .
I can also put some tiesto / deep purple/ Jm Jarre in the mix or do you prefer classical![]()
I wire in parallel pairs linked in series (4 drivers per side) which yields same net impedance as one driver.
So series xover network, Are those off the shelf ports ..?
I use my own active filter on my bass solution. Horn is crossoverless.
Kudos to Daryl and Wilson Audio
The award announcement was on Wilson Audio's Facebook page.Is the Product of the Year issue out already....I am a digital subscriber and have only just received the December issue which states that awards will be in the next issue??
The narrowest room of which I am aware that XVX has been installed is 15'6". Regardless of room width, listening distance is also critical.Hello everyone, this is my first post.
What is the minimum width between the walls to install a XVX?
My listening room have 20 feets of depth and only 12.4 of width. Would be a dream if my room has sufficient width to the XVX.The narrowest room of which I am aware that XVX has been installed is 15'6". Regardless of room width, listening distance is also critical.
