Many claim fuses do matter and the direction too. The engineer in me says he’ll no but yet it does. Usb cables is far more a realistic how or why.
I believe in Pac I’ve put 3A slow blow HiFi Tunning so might be that the same goes into TRP...Does anyone know the fuse value on the GA TRP? Has anyone upgraded theirs? I have had very good success in the past using Synergistic fuses. I know it might sound crazy, but we know USB cables matter (even though 'bits are bits', LOL) so why not fuses?
Thanks.
Lloyd at Banzai just confirmed today that they have resumed shipping to the US (w/o a 40 euro FedEx upcharge - now back to USPS for ~7 euro). Just placed an order for the Psvane 6CA7 Tii's. Will be interesting to compare against the NOS GEC KT66. I'm using the Psvane ACME recti.I just got a pair of NOS GEC KT-66 today. In my setup (Takatsuki 274b), Wall SET amps, NAT Audio preamp, I prefer the Psvane 6CA7s. The GEC was a little too soft for my liking. The Psvane with the Takatsuki rocks. YMMV.
What ever you do don’t increase fuse capacity. The fuse is there to protect the dac.I believe in Pac I’ve put 3A slow blow HiFi Tunning so might be that the same goes into TRP...
While I don’t have the acme from what I hear it’s a good recti. Keep in mind it’s a weighted recti so the. Ps vanes will add air and a more upfront sound. Also presence is added. Now how much you need of this is why you should post when it’s burned in after 50 hours. keep in mind even after 30 hours it still has room for change.
Good luck n enjoy the music
The SR is directional (see instructions) in the sense of the lettering and goes in left to right as I recall. I did have one whose label was put on backwards, so it doesn’t hurt to check. The sound difference will be obvious.
Can’t say it needs that much but there are tubes nos ones that need that much to burn off tizzy sounds. of tubes are left off for long periods I do feel a few hours before they get good. How do you feel on this. Info is always welcome.The Psvane and Shuguang I’ve used needed more towards 250-300 hours to achieve SQ stability.
Hence my choice for the ACME 274b rectifier to kick the GEC KT66's buttI just got a pair of NOS GEC KT-66 today. In my setup (Takatsuki 274b), Wall SET amps, NAT Audio preamp, I prefer the Psvane 6CA7s. The GEC was a little too soft for my liking. The Psvane with the Takatsuki rocks. YMMV.
Hi AlHello cris hope all is well. I don’t own the acme glad I did not push to get it. how do you feel about the gz480 compared to the tak ? Look forward to your thoughts. Did you get to hear a set of Tesla e51 ? got them too now
I also prefer the Psvane 6CA7-II over the GEC KT66 but NOT with the ACME 274b recti![]()
I’m very happy with the Tesla’s they for me are a bit more weighted then the 6ca7. A bit more air n forward but to me it’s best attribute is a lower noise floor.Hi Al
All good here, thanks. I hope you are as well!
The ACME 274b is a nice recti to sparkle up the NOS GEC KT66 (or similar) but IME the Taka, the RK and the GZ480 are better and more linear sounding.
You know I love the Taka and was very curious about the GZ480 and I have to say the GZ480 is excellent. They are a little different in their sonic balance but both are outstanding as well as the RK 5u4g is. Depending on the output tubes, one of those 3 rectis delivers always.
How do you like the Tesla EL51?
Unfortunately I got heavy distortions in my TRP with the Teslas
I was afraid that my pair was faulty but a friend of mine tried them in his TRP and there they obviously sounded excellent.
It looks like I'm the only one where the EL51 does not work...
Btw. in the Pacific, the GZ480 makes for a nice combo with the Taka 300b![]()
It’s not a gain issue other tubes have a higher gain. do both channels do this ?Thanks for your assessment
What is your preferred recti for the EL51?
I guess the GZ480, right?
I need to find out why out of all TRPs, only mine doesn't want to play nice with the EL51s![]()
what WE tubes you compare ?I think Psvane valves are sub par. All they have done is try to copy the best western designs with limited success.
Hi Al
It looks like I'm the only one where the EL51 does not work...![]()
