New Montagna sub
gian60
2,588
2,102
493
I have and i love my Italian speaker Montagna.
Now Montagna did a new sub and my friend,with Montagna speaker,bought one to put in the middle,because has a small room.
In my case i need 2,one near every speaker.
My friend received saturday and is shocked,i will go to listen next days.
The box is made in Ergal and carbon fiber with panels in honeycomb with a special woofer made by Montagna with double magnet in Maxalco,that is Alnico V with Crystal oriented
Really impressive
Now is doing a supertweeter to put on the speaker on the tweeter,with his own filter,so the system will become a 5 way speaker
I forgot,you can choose the cut at 80,100,120,140 hz.
The box has same height and depth of bass speaker,but more large,and being same box and same woofer like the bass of the speaker,but little modified to go more down in frequuency,the sound is very homogenous and you dont listen there is a bubwoofer
Really impressive
nice looking driver there, Gian!
Any T/S parameters available for this beast or if not just basic parameters?
How will you integrate it - does it have on board plate amp / crossover?
Some parameter i will ask to Montagna tomorrow.
My friend bought active,with Montagna amp inside.
I have interest in passive model,with passive crossover same like speaker,where you can choose the cut between 80,100,120,140 hz.
I can use CH M1 mono,to use in passive biamp,one channel for speaker and other channel for sub
Reactions: Audiophile Bill
Sounds goods idea
RS is 22.8 hz at 28 degree
Efficiency of driver is around 96/97 dB
And the volume inside is 230 liters
Interesting, Gian. Any idea of the QTS and xmax?
Yesterday i went to listen this sub from my friend.
He has a small room 18 sqm but the sound is really very good.
The sub work perfectly with the speaker because has same box and driver.Some song we prefer cut at 100 hz and some at 80hz.
The bass is really very good,deep fast and powerful.
A really big upgrade
For my system or Pietro system with a bigger room is better 2 of this mono,to put near the speaker.
Montagna can do also double sixe box with one woofer and one passive radiator woofer in carbon fiber
