Soory duke... you missing nothing; I wasn't correct... but anyway i'd use a phenolicI thought Bonzo suggested a Beryllium diaphragm? Maybe I missed something.
It is actually sounding super smooth now at 1khz.
I am using dsp with a 2nd order LR and mild EQ (small lift above 7khz). However, the dsp is dig in dig out so I have two external DACs and two small tube amps.
I looked at the 18 sound drivers but didn’t find them to have very flat responses, which makes designing more of a challenge. Both Beyma drivers need very little help.
I am not a huge fan of the plastic diaphragms. They can be smoother but lose some realism somehow...don’t know why it’s just what I hear.
This is why the Live Act Audio speaker’s with Coaxial Radian drivers and Be diaphragms are so interesting because they also sounded very lifelike. I will be getting some Radian 475pb Be to compare to the Beyma...that should also be interesting.
Here's some info which Jean-Michel presented at the ETF -
sorry the file is too large so here is a link to it: http://www.rintelen.ch/download/JMMLC_horns_lecture_etf10.pdf
... but anyway i'd use a phenolic![]()
This music, while pleasing to listen to, doesn’t tell much other thsn timing is pretty good.Beyma with Altec woofer
The original Iwata is another type of exponential horn like Tractrix etc. This Horns Iwata is a derivative of that incorporating JMLC principles with regard to mouth termination.I didn't see anything about the Iwata horn in there, but lots of great information. One can see that advanced horn design is a juggling of tradeoffs, informed by the designer's priorities.
Who's making them today, aside from Selenium and PRV?
To find horn drivers with phenolic diaphragma is quite a search for pellets. You must find the daiaphragmas and modify a driver or look for vintage stuff like the RCA-MI series.Who's making them today, aside from Selenium and PRV?
Jean-Michel did many analysis of different horn design... this is his conclusion of designing horns.
To find horn drivers with phenolic diaphragm is quite a search for pellets. You must find the diaphragms and modify a driver or look for vintage stuff like the RCA-MI series.
Also I'm under the impression that a large-format (1.4" throat or larger) phenolic would need a separate tweeter to cover the top octave or so... is this correct?
Hello Duke
Yes you certainly would need a tweeter above it case in point 2470 and especially 2480 2" large format. Drop off at 9K with 1" and 5K 2"
http://www.lansingheritage.org/html/jbl/specs/pro-comp/pro-comp.htm
Yes, that is why I went for a driver that can go low enough to be interesting and still get up close to 20khz.
beryllium drivers like Radian and TAD can go from 500 - 700 to 18k. Some would argue that you need tweeter or 1 inch compression driver anyway to avoid breakup modes.
Hello Bonzo
Quite the opposite. The Be are about as clean as you can get looking at a waterfall plot. You would add more issues if the tweeter wasn't Be as well.
Rob![]()
My experience has been that the primary reason for adding a tweeter to large-format TAD or Radian Beryllium compression drivers is to get a bit more top-end energy and/or a bit better top-end dispersion. Imo the LACK of breakup modes in the top octave actually REDUCES the SPL of big Beryllium compression drivers in that region, as compared with many other compression drivers. And ime even the 1" throat Berylliums aren't terribly loud in their top octave, presumably for the same reason. (This is evident when comparing a Beryllium Radian with its Aluminum counterpart.)
And there is an argument to be made for having a single horn cover the region from the crossover point on up, from the standpoint of preserving the phase relationships in the overtones if nothing else. In other words, imo there is a valid argument for the path Morricab has been traveling.
I have heard two ways of TAD 4003 and of 2001, and I have heard both 4003 and 4001 crossed over to compression driver /dedicated tweeter. And in universum he crosses Radian.950 to 475. I like all approaches, don't really have a choice. The person who has the best Altec I heard prefers no tweeter. [emphasis Duke's]
I have found that the difference is not so much due to 16k or 27k or the 40k of ET 703. Some drivers are more nuanced in the violin range, like TAD and Radian and AER over the Altec, and that is where my choice preference for the highs goes, rather than just an increase in frequency
Agreed. Ime the execution matters more than the underlying philosophy; in other words a designer cannot take comfort in the belief that his way is the right way (which is what we all believe, n'est-ce pas?); he STILL has to get right every little thing that matters.
Yup! And in my experience a nuanced top end enables other desirable attributes.
I like a gently-downward-sloping response curve. But ime this sort of curve only works well when the top end is sufficiently nuanced; that is, when you can hear all the little inner details without the top end being loud. If the top end is not articulate then the speaker sounds boring; but if you make the top end louder so that it IS articulate then it's not as rich and warm and inviting and long-term relaxing. So imo an articulate top end is critical to letting you get away with using what I think is the ideal voicing.
I happen to be a fan of one of the horn designs Jean-Michel covered, the Oblate Spheroid, and it was nice to see it included. Unfortunately imo its depicted modelled response has unrealistic ripples because the model omitted the round-over at the mouth. Give it a Le Cleac'h-class roundover and it will have Le Cleac'h-class smoothness.
That's what I suspected. I'll have to leave the phenolics to the vintage horn and hard-core DIY guys.
