Hard Drive and computer question
Dimfer
659
238
1,605
Canada
Questions for the WBF computer gurus;
with my ever growing music collection, I want to redo my custom built music server (Roon core).
I currently have about 30,000 titles, mostly FLAC, SACD rips, and hi res downloads. currently total storage is 18tb spread in 4 drives.
My goal is long term use, and keep the operating temperature low.
My target s to have about 36 -40 tb of storage.. which is better- have three 16tb hdd or four 10 tb hdd? I’ve read somewhere that 10tb hdds run significantly hotter, is that true? I am looking at WD Reds and Seagte IronWolf.. which is better between the two? or which is best for this application?
I intend to re rip or upsample some files to wav 32/48 which will take more hd space that’s why I am planning to add storage
CPU is a 16 core Threadripper with the ROG motherboard and cooling system on a BeQuiet case. System has been running flawlessly for about a year, mostly in the 40’s. my concern is- will additional hdd space bring more heat? are those external docking systems good proposition? Any more suggestion?
Software Roon Core and HQ Player.
thanks in advance.
Fernando
Do you want the music to be on drives inside your server or are you ok with have an external NAS?
SSD is your friend.....
I have everything in the server in the NAS as well and intend to
I have a couple of NAS setup, everything in the server is in the NAS. one serve as backup of the other. Roon core use the files inside the server, Lumin app use the NAS.
I considered the above option but not sure if it would bring any negative effect on the overall performance of the server. a fanless way of keeping things cool, and away from the rest of the (computer)system.
Best IMO (working for an enterprise storage company) would be five disks in a RAID 5E configuration. Best combination of speed and reliability. I would use HDDs as they are slower but generally more reliable and have higher density (cheaper per TB).
Reactions: Kal Rubinson
Reactions: DonH50
I have worked for storage technology companies for decades in hdd and ssd technologies for high end enterprises and raid 5 is the slowest of all raid setups for writes, good for reads and it’s the cheapest to implement. Also, I wouldn’t use software raid 5, I would use raid technology that is part of an external disk 5 disk enclosure. Also, just because you have a raid 5 setup, you still have to backup your data. No raid setup is perfect and can produce corruptions. also, I wouldn’t put a music server of any kind in the audio room especially if using disk drives, and personal NAS devices are slow.
Even raid 5e is slow for writes compared to other raid configs. The main reason I’m stating this is if using a raid 5(e) on a NAS, this will compound the slowness. I’ve ripped over 2000 cds and I ripped them to a local disk first then I batched them up to move to a raid on a dedicated server running overnight. Also, you might want to use raid 6 instead of 5(e).
