Best XLR connectors money can buy?
Status
Not open for further replies.
ayreman
218
79
258
Ukraine
If I wanted to upgrade my interconnects with the best (and the most expensive!) XLR connectors this planet has to offer, where would I turn to? Anyone?
P.S. For clarity: I don't care if they cost 1 million per pair... I'm looking for the best money can buy!
Go to whichever producer you like and custom order ones to be made from pure gold and platinum and the part you hold in your hand and look at to be covered with as many diamonds as possible to fit in the given space...this might lead you to the desired 7 figure xlr connector and they will for sure do them for you;)
Reactions: Nascimento
It would be WBT silver, but they don't make XLRs... I would guess if you paid them a couple mil they'd design some XLRs for you though. :)
Do you want the connector or a cable?
Maybe talk to Eidolic and see what a (few) million bucks could do?
https://www.facebook.com/Eidolic-578621495591705/
http://www.eidolic.com/Eidolic-Hifi-Audio-About-us.html
4-pin XLR connectors were already done, most likely designing 3-pin ones should be a piece of cake?
http://www.norneaudio.com/litzheim/...-silver-teflon-titanium-barrel-plug-connector
At room temperature silver has an electrical conductivity of 106% IACS which is higher than that of any other metal.
Not that many manufacturers were making XLR connectors with pure silver pins to begin with, though it's only meaningful when you're actually paying them to make male XLR cable connectors + female XLR panel-mount connectors + female XLR cable connectors + male XLR panel-mount connectors.
Since you're already spending that kinda money, no connectors on Earth could beat hardwiring the cables directly because of the resistance etc.
Reactions: Young Skywalker
Specification wise XLR are not top of the food chain and don’t see how expensive metals is not always better too. Unless it’s the bowl of ostrich eggs concept. just saying.
Another alternative is getting in touch with Furutech and ask them about the NCF version of their XLR connectors
MANY THINK THAT BOCCHINO CONNECTORS ARE THE BEST. I HAVE THEM THROUGHOUT MY SYSTEM CONNECTED TO MASTERGUILT ULTRA CABLE.
SINCE CARMINE MAKES THEM TO ORDER THEY CAN TAKE A WHILE, BUT I HAVE FOUR NEW BOCCHINO XLRS THAT I AM WILLING TO PART WITH
Reactions: gleeds and Leif S
If you want the very best cables in the world and you have a budget to match my advice would be to contact Unique Audio about the bespoke cables available from LFD Audio here in the Uk. The commercial sense may be questionable but not their performance.
You can get an insight from my OP A Visit to Miks (CY108) Home
Personally I would look to upgrade your "mercilessly modded" Monitor Audio speakers before I started fretting over better connectors....
That said, my Jorma Prime xlr's sound pretty darn good & use Neutrik connectors. I recall Geoff Merrigan from Tellurium Q commenting that the solder mix and method of soldering the connectors is more important than the connectors themselves (assuming you're using reasonably good connectors). So I wouldn't get too hung up on the blingiest hardware dude.
Reactions: Armsan
The wire used is far more important and while the connector used may matter I doubt anyone can hear it.
Well yes, the wire, insulation and geometry in concert. Interestingly, Jorma Kosky found that the thinner the guage of the copper wire and ceramic glass fibers he used in his cables, the better the sound. That is why their statement cables have a suprisingly narrow gauge.
I can speculate it has less capacitance and induction too leading to a more neutral sound. better more expensive cables are well worth the price. To use a cheap connector would leave something on the table. I think the better cables is due to vast time and effort on creating them.
Reactions: Bodhi
Well, I have a pair of $20k Echole xlr cables just arrived to have their Oyaide plugs replaced with Bocchino xlr...
My interconnects are already terminated with Bocchino XLR. I'm looking to better those. Any ideas? You must've done thorough market research before settling with Bocchino?
If Bocchino are considered to be the best (by many), why are you "willing to part with yours"?
Aside from hardwiring, you might prefer a different plating on these plugs? Depending on what you are trying to achieve, platinum or rhodium for more transparency and linearity or gold for more warmth and body. Also look at upgrading the equipment jacks to minimise losses as well as better match the plugs.
A pair of interconnects for $20K is nice. Can you please describe how the sound in your system changed when you replaced Oyaide plugs with Bocchino XLR?
Status
