Jesus! What is this guy smoking?!
Whatever it is, I want some!
Wow.
I got banned from that??? Hurricane is overpriced?? Yeh I still think it overpriced.
And it funny when you said 2k cable sound close to 7k cable..pfft. Have you ever tried any 7k+ cable in your own system?
And Dragon use silver while Hurricane is copper etc etc how can they be in same signature???
It sound of " Mine two humble System" seriously. And like I said Hurricane make my system sound too fast too much mid too edgy. So?? What if sound bad on my system?? I did not said it would sound bad in your too.
And I said it overprice? Yeh sure you can easily find DIY cable that beat Hurricane at 2k. For Dragon if you not deaf it left Hurricane to dust seriously for what it did to my system it definitely worth the asking prices. Is that answer your Ego questions?
What the problem?? I do not understand I just share my experienced?? You can lick each other Hurricanes. I'm done with this AQ shill community.
Bye.. I suspect your analytical, deductive, and perhaps listening abilities are approximately equal to your lack of writing abilities, with around 30 errors in this post.
Ricjor1 - this reminds me, I found the Tornado on the DAC brought more high end detail but voices became unnatural, lost body and bordered too bright ; this was not an issue with Thunder. it also reminds me when I went from USB Coffee to Diamond, latter brought more detail but it teetered on the edge of brightness with then Naim amp. I kept both just in case, but find brightness isn't such an issue with Diamond on Gryphon amp. This seems to be the way AQ works - more detail can mean less body and more brightness in some set-ups. Glad you're happy!eagle3333,
I agree your system, your room, and your ears. I recently have a similar experience between the AQ Hurricane and Dragon.
I had two Dragon powercords for a home audition. I put one on my DAC and the other on my preamp. My initial thought is the Dragon added a lot of detail. I usually listen with the volume set at 60, but had to reduce it to 58 with the Dragon inserted. After letting the music play for awhile, I did some critical listening for 90 minutes or so. I'm pretty certain that I will keep all Hurricanes and not purchase any Dragon powercords. It isn't because I think the Hurricane is better. I submit they are different and I always say cables are system dependent. In my system the Hurricane is a more balanced cable, where the Dragon is forward to my ears and it's a cable that really highlights details in a way that I don't like. E.g. when I listened to a blues track by KEB MO, with the Dragons the guitar was very forward and dominate, his voice was out of balance and the bass wasn't as full. Returning to the Hurricanes provided excellent balance with detail and fuller bass. There are no absolutes in audio and careful component matching is more important than how much a component cost.
I would get 2 Tornados and use the savings on something else. I did that for my Vandersteen Model 7 subs. My dealer said it was fine and I wouldn't hear a difference.
Yes, you will regret it. You don't want to have anything below PSC+ in your system. And it doesn't matter that it's the subs because the cables sound even when they are not connected (and powering) any component. To all of you, guys, here... do the experiment: get a spare power cord, plug it into your distributer/power filter (or even into the wall) next to your amps (or a preamp) and put the other end of this cord on the floor (do not connect it to anything!). Now sit down and listen to some music. Next, unplug this cord. Listen again. See what I'm talking about? Power cords have a distinct sonic signature even when they are not powering anything. Their mere presence makes the difference!Exactly my thoughts!
My concern is that i know the definition/details is better the higher you go up the ladder. For copper, PSC+ is king. I won't spend crazy money on sub power cables (no way firebird), Thought one step below would suit the situation, so initially i thought hurricane.
Then contemplated on it, its just bass between 50hz and 20 hz. i could use the savings for a planned streamer upgrade. So currently favouring tornado. Which i believe still has PSC+ probably for the current on demand wire. Hope i won't regret it ))
Yes, you will regret it. You don't want to have anything below PSC+ in your system. And it doesn't matter that it's the subs because the cables sound even when they are not connected (and powering) any component. To all of you, guys, here... do the experiment: get a spare power cord, plug it into your distributer/power filter (or even into the wall) next to your amps (or a preamp) and put the other end of this cord on the floor (do not connect it to anything!). Now sit down and listen to some music. Next, unplug this cord. Listen again. See what I'm talking about. Power cords have a distinct sonic signature even when they are not powering anything. Their mere presence makes the difference!
So, Saleh84, you've got to go for the Hurricanes for your subs. I'm using Dragons HC with my REL Stentors
