Actually I was the one who invented the name "Bayz" Audio ... as working for them some 3 years as a kind of adviser. So I know the concept quite well, with its benefits and limitations.
I am designing and operating PA and studio monitoring systems as well, and based on my roughly 30 years experience I know it is very difficult to do proper rock listening at home without "punch", which usually requires front-facing at least 12-inch bass speaker to move some air. Some kind of "bone shaking" required and it is not just mean loud. At least how I am enjoying rock. You can be different of course, it is just my way.
It would have been great to know that you were Bayz Well if you say they can't rock then I am confused. Do the Courante rock like a PA system, NO, understood. We listen to rock differently, I agree.
I wold say that the way I listen to rock is to the way the majority of my customers and visitors listen to rock. Most customers are in home environments and they don't have PA systems in their living rooms
I can play the Courantes to about 90db with 95db peaks in a 700 Sq. Ft. room with a wall to wall 3 D holographic solid soundstage, full bodied sound with deep extension and put on ANY rock including hip-hop and it works for me. Space between each instrument with appropriate air and harmonics coming from each instrument and nothing gives way or collapses.
I think the differentiation must be how each of us listen to rock. I lived with Avantgarde Trios w4/BH"s for 10 years and for me they could rock and sound ALIVE. I don't get the same impact with the Courantes of course, but I listen to any hip-hop or hard rock that I want OR any visitor that I hand the iPad to and so far they have not disappointed me or anyone that has heard them.
Color me confused because I respect that you are part of Bayz etc but I am experiencing something different. Actually it is the difference of terminology regarding listening to rock that is different. For you and many I guess they would not play rock in an acceptable manner, for me they can play rock to the levels that I would listen to even if I had a PA system in the room.
I'm more into 3D palpable, holographic soundstage, with fine detail and resolution than I am into thumping my chest, but that's just me.
