Yes you did, and you apologized. When a video is posted you immediately return back to your old ways like this:
It is this attitude which I have problems with, if you hear these videos you should know something else is going on. If we can continue this conversation without premature ejaculations of this nature I would personally like to.
Now peace has returned to this thread, some quick practical considerations for Tang:
1) Placing the Daizas on carpet is not what they are designed for. It just does not work well.
2) Rubber, compliant, or ball bearing footers defeat most of the Daizas purpose.
3) I do not consider the Daiza to be a replacement for the CMS stand, although it could practically serve that purpose. Sure you can attempt to go there, and you may even end up preferring it that way, but the floor would need to be solid, or its just not an option. The CMS is a stand, the Daiza is a tweak. There is a ~10 fold price differential between them for good reason.
4) My suggestion is to place the Lamms back on the CMS stands.
5) Then try with the Daizas between Lamms and stands but use different solid footers, I am sending you a bunch on Monday.
6) From the video analysis it looks to me like there are some resonance issues with the Lamms on the CMS stands as there appear to be consistent small band spikes at 2K, 4K and some residual at 8K. This could translate into a degree of harshness and/or sibilance.
Also from video analysis the Daizas do seem to significantly reduce those spikes. They may be able to completely remove those if the rubber footers are replaced.
7) Then its just a matter of taking your time to evaluate if you prefer with or without.
8) I have actually learned a thing or 2 from all of this, the remote diagnosing using video is interesting, am going to investigate practical applications.
9) As I understand it, the Bixby voice control agent introduced with the S10 is continuously modifying your microphone input to improve speech recognition. This is something to consider when making video recordings. Just FYI.
As an owner of CMS racks as well as the same amp and preamp as Tang I cannot believe that there are resonance issues with the Lamm on the CMS. CMS racks function on the first law of thermodynamics. simply put IMHO resonance is a non issue.
Emile you heard at my house the same amps on the same amp stand as Tang. There is no resonance
In any case the complaints and the observations against panzerholz/Daiza were about loss of harmonics, micro and macro dynamics not this suggested resonance.
Not to speak out of hand for Bob, but he is a child of the 60’s...these are the magic footersBob at Rhapsody, what type of footers are you using under the 18 or so components that are sitting on these platforms?
Let's go back to the crux of the matter that we disagree on panzerholz and how it affects sound when used in this manner,.
But Ked, that room is GIGANTIC and with moderate music as what the video that was just posted I disagree that it sounds dead. I do think that when you push the Kawero Classics in that room it just doesn't work because the speaker is too small for the monster sized room.The Kondo Kaiser system in Munich is pretty dead, under driven, at least in that room, on a regular basis. I don't have experience with the speaker outside Munich
I recorded a small piece of the Kaiser / Kondo display at the Munich show in 2018. This is panzerholz speakers, racks and stands. Does this sound dead?
Another snippet from the back of the room:
