How does one even know if ones being sold are the "real" ones?
Are they the EL-701s? 10A?
How does one buy a Ching Cheng PC?
EL 701 12.25 amp
Bob,
It would be nice if you amended your post saying specifically that these are NOT the Ching Cheng power cables endorsed by David. Otherwise distracted people who have not be following regularly WBF can buy them by mistake.
Agreed.
That's why I asked my question. Where does one get the ones endorsed by David?
These aren't them Bob.
david
@Steve Williams are you using Chengs or Master Built in your system?
EL701 is just a general number for the connector type. The cable is AWG 14. Probably original CC with David blessing will soon become precious, even more valuable than unobtainium Decca vinyl!. The one you photographed looks NOS!
Bob
I put up pictures as well as the code for the cable. Now can you please let it go
This one looks pretty much like the same type of connectors Steve posted above ...
• https://www.amazon.com/Monoprice-14...3C06S7VN76J&psc=1&refRID=GTZ9DAZ1C3C06S7VN76J
And looking @ the serial number on one of the connectors it is the same here as Steve's photo shows ...
• https://www.amazon.com/Ching-Cheng-...X59HE0XD3BT&psc=1&refRID=8RTRR4RW1X59HE0XD3BT
And same for the one I posted before but one connector is different ...
• https://www.amazon.com/ExpressUSA-C...EPN402M3X8Z&psc=1&refRID=B9S2KRRR4EPN402M3X8Z
So, the first link has the same type of connectors Steve showed us...Monoprice.
Instead of the smaller connector being black it is blue translucide here.
So, please anyone educate me in the art of power cables because for twenty bucks I see no difference. ...Same connectors, same serial number, same price within few dollars.
It is my opinion that the other power cables I posted for the same money, with hospital grade connectors are more attractive financially, solidity, assurance, insurance and I bet they are as naturally performing as Ching Cheng.
* This one is rated @ 15 Amp (the others above are 10
A) ... I really don't known if that would make a difference in "neutrality" sound ... zero idea.
• https://www.amazon.com/dp/B0069FLXLU/ref=psdc_3236443011_t1_B07F7QVPZX
15A here as well ...
• https://www.amazon.com/Cable-Leader...RKX944HC25D&psc=1&refRID=CY36X1HP5RKX944HC25D
I use Ching Cheng PC's for my entire front end except for the Extreme which I have a MB Ultra PC
I use MB PC's for my amps and I have a complete loom of Masterbuilt Ultra IC's connecting the entire system
Any specific reason other than price for not using MB Ultra PCs in the DAC, phono stages and preamplfier?
