This is the successor to the CP350TI and appears from specs to be the same motor but with a plastic dome instead of a Ti dome.
There are people with the opinion that the plastic/polymer domes are better damped than an equivalent metal dome. The drivers I use have either Magnesium, Aluminum or Beryllium with a dampening coating that is sprayed on. I have compared titanium with and without and there is a difference with the dampening. You can also measure the difference in time looking at a CSD measurement. I have no first hand experience using a driver with a polymer dome. I know the M2 compression driver also uses dual polymer rings.
Rob
