(...) Nothing in the belt drive world is getting close to PTP Lenco at it's price point.
Just to have an idea - what is the price of the PTP Lenco?
Here are my two big decks. I use the L70 arm on the ptp because nothing makes the denon 103 sing like that arm.
And also a snap from the bedroom. Yes I know, the L70 shouldnt sit on the floor like that — ive been lazy.
Jesper
David,
Have you ever heard the Commonwealth?
So it seems you hold nothing against DD’s then Ked?
You may be right, it's a definite design feature and not just a whim.As far as I know your turntable is an almost isolated case - the LP is very poorly coupled to the platter. IMHO it should make a much greater difference in sound quality than the drive type.
IME the biggest problem from tables that try to correct speed is the noise they inject back into the AC, or maybe even signal. That is enough to make a stereo sound bad.
Anyway Marc, just goes to show there are many other things and you should stop rimming idlers
So, it's ok to be crude on WBF now?Anyway Marc, just goes to show there are many other things and you should stop rimming idlers
Dave, this argument could be applied to ribbons spkrs too. Only one or two choices back in the day, and I don't believe you were a fan of them then or now. Today, new only Alsyvox. Ditto new idlers today, only Saskia and Blackstone. But a deep passion and appreciative audience for modded and modernised Apogees via Henk, Jon and True Sound. And a deep passion for idlers brought up to date by Dobbins, Anasound, Artisan Fidelity, OMA, PTP, Torqueo etc.Let's get real guys, I love my idlers but it's not as if they conquered the world. We only have a handful of them from the past that everyone's after, if you take out the EMT 927 which is in a league of it's own the remaining 4 (2 Garrards, 1 Lenco and 1 Thorens) are basically 50-60 year old good value alternatives, very musical but they lack resolution. The rest of the idlers were commercial junk. You need to narrow the field to the few manufacturers who made good commercial idlers.
david
I don't think it's so easy to just dismiss them. Just as ribbons won't go away.
Did you have particular models in mind? There are lots of different feedback/correction techniques and they are not all equal. Putting noise back on the line is not uncommon with many electronics. I know Shunyata pays particular attention to this in their power distributors. Just asking for clarity, are you saying this factor is a rational for choosing a 'table's drive mechanism?
Bonzo and I agree that implementation varies across many direct drive tables. It's a tough argument to lump all DDs into one category then place judgement on that category. Very very few DD manufacturers - or TT makers of any sort - will publish numbers about the accuracy of their tables much less details of their drive mechanisms. Many different factors play a role in a 'tables character or sound, and when it comes to speed accuracy, unless there is published data, some manufacturers will deflect to those factors rather than discuss accuracy in detail.
Once you hear the difference, you may appreciate stable high accuracy. Once you hear a 'table with stable high accuracy you can appreciate stable extreme accuracy even more. Both are well beyond the bounds of using audible pitch stability or wow & flutter as a gauge, the latter now, imo, being a legacy or antique measurement. If you think our ears are highly sensitive and that time coherence in a speaker makes a positive difference, you may appreciate stable time accuracy in a turntable.
To slightly modify the last two sentences of my Monaco 2.0 coverage: "There is an argument that hyper accuracy doesn’t matter because vinyl records are too imperfect for it to make a difference. Withthe new Monaco 2.0, new direct drive technology, that argument goes up in smoke."
Dave will understand my argument even if you don't/won't/can't.Marc, this argument can also apply to Beethoven, Bach, etc. If someone likes old composers, they have to acknowledge vintage idlers are great. Ditto goes for Pele, Martina Navratilova, etc.
In short, let's be on point
