GREAT POST!!! I note that the positioning of your speakers certainly 'appears' to be similar to how Gryphon has set up their Pendragons before in various rooms. Fantastic system! Would love to know more about how you came to buy all Goebel cable? What else did you audition/try?
Hi LL21
I came across Goebel when I was living overseas . It was recommended and used in quite a few of the systems I heard and liked on my travels. I used to run all Nordost Valhalla and then looked for a change. Tried various Gryphon cables, Transparent Audio ,Siltech and a few others ...I then tried the Goebel cables and have not had the urge to change since. Been so long since I have compared cables but they were one of the few cables that really surprised and impressed in my Gryphon systems......like everything amplified but with a wonderful smoothness. Now that I have moved back to Australia the options of trying very high end cables are very very limited especially so in Western Australia .... I did try and organize a shootout between Nordost Odin 2 and my existing Goebel cables but the distributor could not supply required cables for my system and I think was a little concerned the outcome my not have been favorable .I will try again though always nice to check if there are any cables better suited to my taste and system. I know you are running a Mephisto amplifier do you have any suggestions or favorites for Gryphon amplification...be great to hear some suggestions.
