Of course, as in all things audio. Any suggestion that the U1 Mini suffers by having an internal SMPS that can't be upgraded by an external LPS unit?
I believe the U1 can.
Bill, the U1 is on my radar too, my dealer is investigating whether the step up to the U1 is indeed justified re better psu. We're talking 3x cost of U1 Mini.The original U1 (not the U1 Mini) comes standard with an external dual-toroidal linear power supply, part of the reason for its much higher cost.
Thank you, but I don’t want to add a computer device. I don’t need Roon..
I intend to plug a streamer into an ethernet jack
Bingo, why is there not a single box Dac/Streamer/Server?That’s sorta like saying you only want a Wi-Fi router and you’ll skip the cable modem because you’re going wireless...
I understand your frustration. I think the whole streaming thing is kind of a giant PITA. There are numerous people that would go streaming if it was simple, simple like a CD player.
Hi Ron,
If you really want simple I would advise you to look at the Lumin U1Mini.
http://www.luminmusic.com/lumin-u1-mini.html
All it requires is an Ethernet cable and iPad. Then connect the U1 mini to your dac by its many output choices.
You realize a streamer is a computer device. No streamer has a better user interface than Roon.
Yes, I realize a streamer is a computer device. Though they are very useful and efficient I do not like computer devices, which is why I never wanted one connected to my stereo.
My understanding is that Roon has much more information and metadata than I personally have any interest in dealing with. If the Qobuz app is half as easy to use as the Spotify app then I will be very happy with Qobuz. I do not need Roon + Qobuz.
I do think you have some misinformation mregarding Roon, Yes Roon may have a lot of information that “can” be accessed and I use almost none of it. What it does do is make using something such as Qobuz or tidal seamless.
Thank you!
What does you mean that Roon makes Qobuz seamless?
Isn’t using Qobuz on its own app already seamless? How does Roon help Qobuz run better on the Qobuz app?
Step 1: Set device on shelf.
Step 2: Hook device to system and internet.
Step 3: Start DACing, servering and streaming off tablet/phone UI.
