I have played several times with three-phase generators for turntable motors - the first time was long ago driving the Oracle Delphi III brushless motor without servo, later with a spare Studer A80 capstan motor that I intended to use to drive the Forsell air bearing flywheel. In order to get the proper voltage I used three step-transformers connected to a multichannel amplifier ...
Looking at the signals of an accelerometer connected to Spectraplus I could adjust the amplitudes of each phase for minimum vibration - it depends on motor drag. It was a nice exercise.
However we can not be sure that bypassing mechanical controllers improves subject sound quality. They rely on drag, and in the same way the viscosity of oil (or pressure of air in air bearing...) affects the sound quality, they are part of system and its sound characteristics. As people say, they were part of the designer intentions.
BTW, I gave up on three phase project after I saw the Apolyt turntable and I am finishing the system with a spare A80 capstan motor controller. If it is good enough for the Apolyt and A80 capstan it should be good enough for my modest Forsell turntable ...
All IMHO, YMMV surely.
