Site Founder, Site Co-Owner, Administrator
Just to point that I used it for the ML3 - the M1.2 sounds different. Later I will come back to the subject.
Micro
of course they might sound different. One is an SET and the other is not
Lit is different from lighter but the experiences are then closer in terms of mood created than say with the thematic opposites, darker or weighty which add a more sombre or serious quality for me. I don’t see brighter as necessarily irritating unless there are unpleasant distortions but just brighter than a comparative darker sound. Absolutely balanced is balanced and I would have thought not by definition any of the terms above. Ked my preference is not very far from the middle but that is just the way with Tao.I don't think brighter is opposite of darker, as brighter signifies an irritating high end. Lighter is not either, because while it will have the top end dark is missing, lighter to me indicates a lack of low end. If it is not dark, nor light, it will be balanced across, top to down. Lit is different from lighter.
Your friend I understand uses three pairs ML3. I would have to eat ramen or Burger King for the rest of the year to do that...hehe.Post #701 by Gian60 is an experiment I would try. I recall a similar situation I heard with a friend's Magico horn speakers. He used the Lamm ML3 on the midrange and the Lamm M1.2 on the highs.
Tim, while I’ve associated darker also with more soulful and possibly at times even feeling heavier and at the opposite end things as more lit up, brighter more spirited and or even possibly lighter. Most usually tho simply darker and brighter come first to mind as the most fitting reflective duality in what I’d see as a fairly common and useful sonic gradation.
the background is more candle lit, and less open, compared to diffuse daylight. so you did not see all the way into the edges of the soundstage. the darts allowed a less restricted view. colors are a bit deeper and denser. deeper than real? probably. softer too. more natural. too natural? maybe. a different version of reality.
the tonal balance is more liquid and textural, but not congested. the dart mono's are more transparent. both amps cover all the bases, only that the emphasis is different. the ML3's were not closed in on top as far as high end extension, but not nearly as open on top as the darts. it's rare for any amp to be as open on top as the darts but still have a natural tonality (not heard it).
and turning impressions into words is always a challenge.
Have you evaluated a Spectral preamp in this specific context (as an alternative to the Soulution pre)?
(I would think a Spectral pre also would accomplish these same characteristics you are crediting with the Soulution pre.)
Tim, I love your effort to render words with precision in our audio context, and the way you evaluate and weigh the meanings of the words and hold the words up to the light and look at them from the different angles of our audio perspective.
Based on guesses, unverified on my part, I relate to what you say up there. However, I know if with valve amps, if venue context or backwall reflections are less discernible, the trick is to (...) add a preamp like Soulution or maybe Boulder.
This is very different to combining valve pre with SS power
Yes, the topic of combining valves with solid-state, which and where, has a long history without coming to firm rules or even guidelines. No guaranteed synergy without getting to specific models. Any direction would seem properly driven by speaker choice. And to some extent music - that's full orchestral in my room.
I've only heard the Soulution amps with Magico and (of all choices) Verity. For a while (way back) I was all solid-state, then all tube for many years (CJ, Atma-Sphere). At this point I'm living with ARC 10's up front and the Lamm SS amps. The strengths of each seem to will out with the speakers I have. Room (17x20) is too smal for larger horns. BUT the all Lamm system currently in play is very easy on my ears.
I don't know if Mr. Lamm has thought about it, or even if its possible in theory, to bridge two M1.2s, but I'd listen to 'em.![]()
