Moving beyond the vinyl/digital debate, do you agree with Paul McGowan's comment that a system should be optimized for a particular format?
From my personal experience when I had both formats, I totally agree with that premise.
BruceB once posted on WBF why the does different mastering for analog and digital - perhaps he can help on this subject.
I would immediately suggest room bass performance. Digital bass needs very good behavior of room in the low bass. And we can't use the trick of switching the subs off with top digital - IMHO digital needs to full spectra to sound great. Anything that goes wrong in this area robs dimension and fluidity to digital.
But is more than bass. I can't avoid returning to information. Digital has more information along all the spectra. Something wrong in the room - this usually means excessive or uneven reflections - will exaggerate part of this information, creating an unpleasing, artificial sound.
The best digital I listened was always in large or very large rooms - and curiously vinyl playback was not exceptional on them.
Peter, I've just put in the equivalent of two dozen pricey and not so pricey changes to my vinyl playback, and really gone to town on optimisation. The Stacore platform being the most visible and significant change.Marc, it seems to me that Mike has address all those things in his system for both formats. In your own system, have you chosen to optimize one format over the other? If so, what have you done for one that you have not done for the other, and do you make specific choices regarding room treatments, speaker position or something else to optimized your system/room for one over the other?
Paul seems to suggest, that for those people who listen to both formats, they have optimized one over the other. I'm curious to learn if this is actually the case. I understand for those who have only one format that they think it sounds good with that format. But does that really mean that if one temporarily tried the other source format, the preference for one format over the other is more dependent on how the room is optimized than it is for the inherent differences between the formats?
Do we really need to listen to each format separately in its own optimized setting to form judgements about the sound of each?
I am shocked, shocked, that people are ignoring the best analogue source and playback, tape - good old 15ips 2 track tape! Cost of equipment - very comparable to the better digital and vinyl. My quite high end tape playback rig costs just about the same as my playback DACs (one stereo and one mch) and my vinyl rig . Cost of source materal - expensive, but not all are crazy if you know what you are doing. Sources - more limited than vinyl or digital - but not as limited as you think if you know what you are doing (at least several thousand albums).
Larry
Yes, very interesting. I wonder what MikeL would have to say about one system not being able to do both well. Also, if one follows the advice about comparing digital to vinyl in different systems, each optimized for the one format, it would be impossible to compare apples to apples because of variables with the context, system components, music, room, etc. So what he is really suggesting is a very broad general opinion about each format.
I've often wondered what it would be like to hear Al M's Yggy DAC in my system or my SME in his system. I guess that would just be a waste of time.
Larry
if we just look at dollars i am not only equally invested in vinyl as digital source gear, but also relatively equally invested in RTR tape. and all my grounding and anti-resonance is applied to both digital and vinyl (not tape sources specifically). you have to remember that my dart pre mostly supports vinyl with 2 phono stages, the MSB has it's own world class preamp were i to not have vinyl. then there are multiple arms and cartridges, none inexpensive. and there are always pieces coming and going in any involved system like mine. we can forget just how spendy these things are.
my stated general system building approach has always been optimization of each format, and a system that gets out of the way of the music and is not restrictive or leaning this way or that way.
i could not respect Micro (Francisco) more, but on this narrow format optimization issue don't personally follow his direction in my approach. i don't doubt that he does focus more on optimizing his digital. i do agree with his views about the significance of gear and system synergy and how that relates to judging gear objectively. i too have focused on that. so we can all learn from that perspective.
Mike,
With such unanimity I would feel tempted to say that your room and system favor one of the formats ...
This so turns the logic of MikeL’s point upside down that I simply have to hope you are joking.
Ron, at least we can contend your's and Al's point that maybe Paul hasn't based on his view on excellent analog. Clearaudio w Lyra doesn't quite fit my idea of the analog I'd settle with, but it's indeed a good comparator to digital, in having good detail retrieval, and a crisp, clear perspective on music.
. . . it's indeed a good comparator to digital, in having good detail retrieval, and a crisp, clear perspective on music.
At least we're not comparing 2019 top digital with a Linn LP12 circa 1973 LOL.
For my part, after boring people to tears in the 80s extolling vinyl over CD, the last 5 years with a stellar cdp that replicates a lot of what I love from the best tts, has really got me eating humble pie. Add in regular exposure to the best digital I know ie SGM/Aqua, and I find fewer and fewer reasons to promote vinyl over digital. But the areas where analog still prevails remain as strong as ever, and I still judge lp playback to shade it over digital. However it's a converging target.
