Ah I see. Since the wire with gain is a fictional ideal I guess every part of every system is a tweak.
Exactly!
Since every piece of electronics on the planet deviates from this definition I think it is therefore a LITTLE bit too broad.An alternative formulation:
Anything that deviates from an wire with gain is a tweak. Speaker modifications and acoustic treatments should not be considered tweaks as they are allowed forms of preference. A tweak must be something not allowed ... In case of doubt a null test is the only allowed method to escape from the shame of being a tweak.
What you say about power cables applies to every part of the system. The power cable is just easier to switch out.
Dave, that is certainly true. A power cord is easier to switch out. And everything we do can potentially change the sound of our systems. The point that I am trying to make is that electronics usually come with power cords. They also come with footers. I would argue that footers and power cords are tweaks, because we can choose to alter the sound of the component we have bought by changing parts of that component that were supplied with it when we bought it. Tubes are similar.
Somehow, speakers, electronics, sources, and signal cables seem different to me. They comprise the fundamental components of an audio system and are all required for the system to function. The system will function without the need to buy aftermarket power cords and footers.
Hi Peter,
All of my components have factory installed grounding terminals, I bought the grounding cables and added them. Is this a tweak? The sound did change but is it different than adding dedicated lines or furutech outlets?
Dave
I would say "yes". It's a tweak, or a modification from what the factory supplied. In some cases it could be a factory option/upgrade. It doesn't really matter what you call it, IMO. What matters is that you prefer the change. That seems like good news and cause for joy.
We could also start to discuss routine maintenance like replacing tubes, turntable belts, contact cleaners, etc. At some point, we get lost in semantics and definitions.
Room treatment is NOT a tweak!
It is as important, if not more so, than any other piece of equipment. It is much more important to the sound of the overall system than cables, for example.
I can send you a Tripple Crown and a Ching Cheng to a/b for fun my friend.2019 will be my year for tweaks
I am very happy with my system but need some not very expensive tweaks to improve
I need Kuro power cord for M1 20A,i have yet the original
Kind regards,
Tang
I actually never tried stock cords. So I cant answer that.Do prefer the Ching Cheng over stock?
NIce thread, Barry. What is and is not a tweak? Right now I am listening to the stock power cords that came with my Pass preamp and phono stage. I am leaning toward the notion that after-market power cords are tweaks. Sure, one needs them for the component to work, but most components come with power cords. The stock cords are essential. Anything different is a tweak. I am now finding that other power cords simply change the sound of these components, just like footers do. Perhaps some are better, but most just seem to be different.
I am going through a phase now where I am re-evaluating all of the tweaks in my system. I am finding that simpler is better and that many tweaks simply color or change the sound, more or less, to one's liking. One hears differences, often an increase in "detail" but upon longer listening, it is simply a changed emphasis on a particular frequency range and not really a advance or movement closer to the recording or to the sound of the real thing. I find it an often frustrating exercise, and quite ear opening over time. When confused, unsure or lost, I tend to refer back to ddk's preference of "natural". Does a particular tweak make the overall system sound more "natural" or not? That is the question these days.
Now Peter that is a challenge which I hadn't even considered.Barry,
Now question: have you tried removing the Ultra 5s and SSs from the system altogether?
