Sure, there is. There are many, many programs/apps to do it.Is there a way to batch convert flac files to wave?
I just let JRiver do it but I have used others like dbPowerAmp, X recoder3 and AudioMuxer. There are many free ones but I cannot remember any of them.Can you nominate a few you would recommend?
J River will handle this easily.Is there a way to batch convert flac files to wave?
For the same reason (and because I am not an Apple user), I chose FLAC.For what it's worth, I chose to use AIFF instead of WAV formats because the latter doesn't support the use of tagging, attached to the .wav file, for management of the library.
Cost per Tb?After all the work, time, effort to rip your library, you should consider backing it up to the cloud for protection against data loss, server theft, or fire. I found that AWS offered a secure, fair and economical service called "GLACIER" that can work transparently with your server such as Synology.
I have about 5 TB stored and am currently paying about $22/month. Outfits like Carbonite etc, were talking numbers over a $1000/yr.For the same reason (and because I am not an Apple user), I chose FLAC.
Cost per Tb?
I guess I should be more specific:
I have 16,000 cd's on my NAS in several folders. The folders contain files in various formats. I want to convert just the flac files to wave.
1. Can I install a program on my NAS to do the conversion?
2. I don't want to keep both formats of a give cd after conversion, just the wave file. The flac file will have to be automatically deleted by the conversion program. (Yes I have a complete backup) do to space available.
Possible?
OK. I'll stick to my current setup of on-site and off-site physical backups.I have about 5 TB stored and am currently paying about $22/month.
You should tell us what NAS it is as the most popular ones, QNAP and Synology, have libraries of applications for many things.1. Can I install a program on my NAS to do the conversion?
Agreed but Kingsrule has not told us what he is using.J River will let you build a complete library from multiple folders and then sort by file type. Select all the types to convert. It has options to replace the original file, etc.
And just FYI, it's not the same thing to play a non-lossy compressed file and compare this to an uncompressed CD spinning. This is why I rip and play only .wav files. Your system has to be pretty refined to hear the difference though.
Steve N.
Empirical Audio
