Thanks Jack. I wish Alexia/Alexx were more efficient.
Vladimir still has Maxx 3s.
Y
Yes. Gerhard of Ayon is the international distributor for the LumenWhite. He is a regular in Bangkok. 60 watts SET with strong current can run the speakers flawlessly. Not a mainstream speaker. It has a magic of Zellaton with more bass at less than half the price. I asked if I could get these speakers with black drivers once. He said it's Lumen "WHITE."
Kind regards,
Tang
With what amplifier?
In a modest sized room with a robust 25-30 watt SET you can get really good results with a speaker of such specs. We have demonstrated this a number of times with the Thiel CS3.7. Of course having few more dB/watt would be nice. For a SET with a good output trafo the impedance would not be a problem.91db, 4-Ohms/ minimum ~2.9 at 24Hz
I don't know that he uses only one amp, given his choices. We were talking preamps and phonos, but I'll try remembering to ask next time.
I do know that you cannot solely use Wilson specs to gauge a good match, regardless what Atkinson says.
I would be interested in their JBL Hartsfield reproduction...Have you heard or heard of Classic Audio Loudspeakers? (sometimes known as Classic Audio Reproduction CAR) Field coil driver. 16Ohm
They are in the state next to me. I don't much about them. They always show with Atma-Sphere.
http://classicaudioloudspeakers.com/cgi-bin/index.pl?fs=2&upper=25&content=26
https://www.lansche-audio.com/products/s-series/no-4-2/
I had been happy with Lansche 4.1 for 11 years.
It has pristine treble out of plasma tweeter and excellent dynamics out of active two 10 inch woofers.
It also work well with tube amplifier with high efficiency.
Specifikation
Description
semi-active speakerDesign2-way closed speaker with integrated active subwooferTweeter1 x 0,3 in. CORONA plasma tweeterMidwoofer1 x 8 in. paper-coated cone active Woofer2 x 10 in. long neck construction
Crossover Frequencies
2.5 kHz
Impedance (nominal)
8 ? (minimum 6.2 ?)Sensivity96 dB / 1 W / 1 m
Frequency range
15 Hz - 150 kHz ±3 dBDimension44.0 x 11.4 x 20.0 in.. (HxWxD) Weight154 lbs. (70 kg)Amplifier1 x 1.200 Watt (power output)
http://www.aaudioimports.com/ShowBrand.asp?hBrand=19Thanks. The passive Cubus Mk.II with its 96dB efficiency at 8 ? also looks interesting.
Alas, no US distribution.
Lansche has a US distributor.
They will order Cubus Mk. II for you.
I love the Cubus driven by excellent tube ampsThanks. The passive Cubus Mk.II with its 96dB efficiency at 8 ? also looks interesting.
A tiny little bit bulky visually, though![]()
Thanks for your feedback Christoph. Can you offer further insight to their sound or strengths?
...or anyone. Thanks.
I too liked the sound of these speakers...at least until they started demoing with Class D amps...then they revealed the dryness of those kinds of amps.
Back when I was a dealer for KR Audio, I sold a couple of Kronzilla stereo amps to a man in Switzerland that had the predecessor to the Cubus, called Goa, which sounded awesome driven by the KRs. They were 100 db/watt and had active xover for the bass, thus the need for two amps. The ion tweeter of course is effortless but for me the real trick is the presence from the midband.
So Tim, did you end up evaluating any of these options?
