Ron, I never tried my Stacores under my tubed monos, but on the basis of how impressive Stacore has been under my tt, cdp and balanced transformer, you're in for a treat.
Yeah, OK, I'd forgotten you were running mono blocks, so that's where the 3 comes from... Good feedback on the differences with them inactive. I'd actually be interested if you could deactivate just the 30/12 while leaving the monos active, and vice versa. Just for another datapoint as to whether or not the amp vs the table isolation is a bigger contributor.![]()
Bazelio, I may get around to doing that comparison. Right now my system is dismantled so that I can do my semi-annual cleaning with DeoXit of all connections. It will be back up and running in a day or two. It's too hot right now to listen to my amps anyway. And my Pass pre and phono need a couple days of being powered on after shut off to sound good again.
Two days ago Peter and I enjoyed an evening of Beethoven string quartets on his system. The Quartetto Italiano gave wonderful performances of the Razumovsky quartets op. 59, written by Beethoven soon after his revolutionary Symphony No. 3, op. 55, the 'Eroica', and the Appassionata piano sonata op. 57. We listened to all three quartets in this series.
It was an immensely engaging musical experience. The dynamic sweep of the music was extraordinarily well portrayed, with each dynamic inflection vividly being carved out. The separation of instruments was spectacular, you could follow each musical line with ease. The cello sound had a beguiling, well defined corporeality. The system was a great communicator of the architecture and emotion of these string quartets.
Thank you, Peter, for a wonderful evening of music!
. . . It was an immensely engaging musical experience. The dynamic sweep of the music was extraordinarily well portrayed, with each dynamic inflection vividly being carved out. The separation of instruments was spectacular, you could follow each musical line with ease. The cello sound had a beguiling, well defined corporeality. The system was a great communicator of the architecture and emotion of these string quartets.
This is very beautifully written, Al! Your enthusiasm for, and appreciation of, Peter’s system shines through clearly!
You are very welcome, Al. Thank you for your beautifully written post. We often discuss the sound of components and sometimes the sound of systems in rooms. Rarely do we discuss the emotional impact of listening to music through our systems. I'm glad you enjoyed the evening.
Al came over two times last week. The first time to simply hear my system and a couple of particular recordings that I wanted to share with him. We have been discussing amongst our Boston audio group the impression of speed and whether or not a particular component, in this case my Pass XP25, was "slowing" down the sound of transients relative to the sound from other digital components in other systems. That is a hard thing to judge, in my opinion, not having digital in my own system, and trying to assess such things across formats and recordings with possibly different masterings in other systems.
Anyway, on the first night, Al and I did hear a slightly veiled sound on the Beethoven quartets which restricted transparency. I raised the arm height by 0.5mm and that did the trick. The sound became more open and clean sounding. The sound was not at all slow and the speed was quite convincing. Perhaps it is not precisely as fast as live, but there is no sense that it is slow or that the speed detracts from the enjoyment of the music. That was the first night.
Al then asked if he could come over the next evening to simply listen to Beethoven's Middle String quartets, Op. 59 in its entirety on my system. Al does not have this recording on digital, so impressed with the VTA change from the night before, he wanted to hear more and came over the following evening. We had a nice dinner and then came back and simply listened and enjoyed the emersion in the beautiful music. This, for me, is what the hobby is all about. We have to work on our systems to get them to the point where we can then just listen and enjoy.
Congratulations, Peter! You have achieved natural and convincing sound with an amazing system!
The question of whether your solid-state and analog preamplifier is "slowing" down the sound of transients in your analog-source system compared to the sound of transients in other, digital-source systems seems to me so convoluted on its face that the inquirer should go back to the drawing board and formulate a logical question. I also find in the question an inherently pro-digital bias: perhaps the digital component is unnaturally accentuating transients in the system of which this digital component is a part?
I continue to be puzzled that small VTA adjustments make seemingly significant sonic differences in your system. That a small VTA adjustment elevates the sound from “slightly veiled” to “more open and clear” is puzzling to me. What is your theory as to why other turntable operators don’t report such significant differences in sound from small changes in VTA?
Peter, Al, David
So u can perfectly measure .5mm every time? It is ALWAYS reproducible?
The record is PERFECTLY flat so there is NO deviation from the perfect .5mm adjustment as the record is played?
Really, these kinds of observations are getting a bit out there.
Dear Ron,
Setting the VTA/SRA correctly has significant impact on the sound specially when dealing with multiple arms & cartridges. One reason that you don't hear people talking about it is that they're struggling with it, it's not trivial +/- 0.5mm can be crucial.
david
Peter, Al, David
(...) Anyway, on the first night, Al and I did hear a slightly veiled sound on the Beethoven quartets which restricted transparency. I raised the arm height by 0.5mm and that did the trick. The sound became more open and clean sounding. The sound was not at all slow and the speed was quite convincing. Perhaps it is not precisely as fast as live, but there is no sense that it is slow or that the speed detracts from the enjoyment of the music. That was the first night. (...)
Peter,
.5mm in a 12" tonearm means a .1 degree variation in angle. If recordings go from veiled and non transparent to marvelous with such variation IMHO probably this means that you have developed an extraordinary sensitivity to some fine particular detail of the recording and are taking it for fundamental for your enjoyment.
Please understand that, even discounting for the usual audiophile hyperbole, what you are describing an enormous difference!
IMHO the differences due to changes in stylus profile due to normal use along the life of the stylus will be much higher than that. Or a simple change of height of .05 mm in cartridge tip to base distance due to aging of the suspension will produce a .5 degree change in SRA - five times higher that what you are adjusting.
I hope I got the geometry and math right, please correct me if I swapped the zeros ...![]()
Thank you Fransisco. I appreciate your opinion.
Here is what I wrote: "Anyway, on the first night, Al and I did hear a slightly veiled sound on the Beethoven quartets which restricted transparency. I raised the arm height by 0.5mm and that did the trick. The sound became more open and clean sounding." That is not the same as you suggest: "If recordings go from veiled and non transparent to marvelous with such variation...."
"More open and clean sounding" is not the same as "marvelous". And "slightly veiled sound...which restricted transparency is not "veiled and non transparent". You are changing the words, and I would suggest changing the meaning at the same time. I think you and I may disagree that what I am describing is "an enormous difference". These are all matters of degree, pardon the pun. My point is that the sound improved. You are right that a 0.5mm height change in a 12" arm is about 1/10th of a degree. I don't know what to say except that that particular recording sounded better. I think Al M. made additional comments about the effect of that 0.1 degree SRA change. The improvement also contributed to his enjoyment of the recording and involvement with the music.
I don't know about stylus wear or suspension fatigue over time. I have noticed that I have adjusted SRA as the cartridge ages and also with different temperature and humidity conditions.
I accept that you think it is audiophile hyperbole, however, Ron did not drive up with his blue and red lights flashing to issue us a warning.
People know I don’t do arm cart setup by myself. I have a tonearm guy do that for me. I am lazy. Only after a David made me learn step by step to install the 3012r with the Opus and taught me where and what to listen for when adjusting vta, I realized I hadn’t been hearing the best of what each cart I own has to offer. The sound my tonearm guy set up for me became just very good but not great. If I don’t adjust my vta on a cart right, it would just sound a notch or two below the one with the right angle. This given that my tonearm guy initially setup the arm cart accurately to a proper protractor. It is also not only the vta, the tracking force also plays role. They seem to be interrelated. When I lowered the tracking force of AtlasSL, I had to readjust the vta to be rewarded with even better sound than when David set up for me....hehe. The truth is if I hadn’t been coached what to hear it probably took me years and years to find out myself. I am no expert. But now that I have some knowledge how to tune the sound, I actually have a lot more fun playing trying out different parameters and learn from results. The vta does make a difference between an excellent sound and a magical sound (tubes required
Kind regards,
Tang
