3. The rising annual cost of electricity by 4-6 cents per kWh
Not sure where you got this, but it isn't true.
I just forgot about audio and enviously looked at your first post concerning economics - you refer that you spend around usd 7000 per year with an average anual use of 14,452 kWh - you really pay electricity at more than the the double of the average price of Europe ~around 24 US cents. At those prices people with available area should surely invest in solar panels and sell electricity to others - it looks very profitable. Nowhere in the world I have seen alternative energy investments being fully paid in less than four years!
BTW, I find astonishing that a company can supply a full warranty of 25 years on consumer items, particularly as they are subjected to outdoor conditions and service should be expensive due to access and labor.
Very much so, everything in our game is context related so the data needs to be qualified as well as quantified.It is why I pointed that we should be careful about generalizations and should dig in the technical issues and implementations - Steve owns Lamm equipment, known to be intensively filtered by special RFI power line filter and particularly RFI insensitive - Valdimir Lamm takes this subject very seriously.
It is a no brainer Davey and my gut is telling me that those with problems have older generation solar systems that use string inverters or a central inverter
BTW I spoke to them today about replacing the wire from the street to the panel box. Can you tell me exactly what you did. Do I remember your saying that the concrete had to be removed to get at the wire conduit
Well, these were connectors that the utility company supplied...and are more robust than the old connections. I believe that they were made out of Copper vs. the older brass versions( in my instance...this may not apply to your particular transformer...based on its age). Only the utility company can actually work on their transformers, but you can request this upgrade from them...IF you are replacing the feeder cable...which BTW ONLY the utility company ( SDG&E) can install at their connection to the transformer.Can you elaborate on the upgraded connectors that were used
Do you have SDGE
Solar Power? What happens when it rains or it's cloudy at nighttime? What about winter? Maybe someone builds a high rise office and blocks out your sun?
Actually, you post a good question. Rain is something that is almost an anomaly in S.Calf. However, what happens when it is cloudy, or at night. This is actually a pretty good question. The answer is that one is always connected to the electrical grid, so when you are not supplying power to the grid...(think of it like you are a mini generating plant); then you are taking it off the grid...like all other electrical consumers. At night, you are using the grid, when it is cloudy, same thing, when it is raining, same thing...Solar Power? What happens when it rains or it's cloudy at nighttime? What about winter? Maybe someone builds a high rise office and blocks out your sun?
4-6 cents would be a 25% annual increase in power costs - don't think so. these are regulated utilities, guys.
face it, Doc - you use a lot of energy if you're in Tier 3 a lot (that's 400% higher than base) and pay for it. that's really all. LEDs and a Nest isn't going to change things that much at that load. I assume you already have low E double pane argon windows, etc. to reduce your usage footprint.
Davey, you bring up an interesting subject, and one that may be a bit off topic. Energy is one thing. Water is another. When will So. Cal, Arizona, Nevada run out of adequate water supplies? Perhaps a subject for another thread.
