American Sound AS-2000 Installations- Far East (Tango)
Bill, it's a game not all of us are compelled to play.
Guys - I am not following why one needs or wishes for so many permutations of arms / carts or even just carts assuming same arm 4 times?
I can understand this “game” might be fun but I would find it rather distracting - I guess each to their own.
Imagine 1 favorite dish for every meal, everyday; vs 4 favorites dishes and possibility of having and trying many more along with sides and various desserts. There's a lot in high end audio to discover and enjoy, both for music and sound you can do that here at will.
david
We one arm/one cart guys are slumming it on Big Macs three times a day
david
Hi David,
For me the “dishes” are the music itself - as in my collection of LPs.
Anyway - each to their own. Enjoy.
Reactions: tima
Sure Francisco, I guess if you plonked an AS in front of me w four arms, and any number of carts, I guess I'd be marginally tempted to keep the lot LOL.
I was enough of a bore in the 80s berating people for dumping vinyl, I'm not going to start telling analogheads to restrict their enjoyment.
If you have the SME 3012R, or other arms with the bayonet attachment, you can play the game with cartridges. It's a lot cheaper.
I used to think that way. Once you realize how simple and fast cart changes can be with bayonet, the ability to use classic vintage carts and SPU's... it becomes addicting. Doing the same on fixed arms is not so easy pulling wire pins, switching out the cart from the head shell, ect and going through a more complicated and time consuming alignment process.
Are you using slotted headshells to avoid adjusting the tonearm pivot to turntable bearing distance every time you change the cartridge?
Hi David,
Then look at it as having those meals cooked by a number of the international gourmet chefs, current and old, on demand. But like you said, no one's pushing anything on anyone.
david
He's mostly using the fixed SME headshells, setting up alignment with the gauges I make is very fast and convenient.
david
Most of my headshells are the SME (they sound great) so I adjust the sliding base of the tone arm each time. With the DB Protractor recommended by DDK it only takes 1 minute.
Personally I find moving the base a lot easier for setup than the cartridge in a headshell and really miss that option setting up non SME tonearms.
david
david
I am not understanding you - SME headshells have fixed holes, what is the point of using the gauges?
david
I agree with this point - it becomes as simple as setting a linear tonearm!
Without the smiling Imoji I’m still guessing your post is tongue in cheek. The gauge eliminates using the cartridge for alignment and with straight side edges it can be done very quickly using the DB Protractor or equivalent.
david
1 minute?
If you use a slotted head shell you don't have to make any adjustments once it is set. How is that not easier?
david
Yes, there was an implicit smile - I have been using the Forsell for many years. Just 120 seconds to change the cartridge - unless the cartridge pins were not standard and the pins needed some adjustment!
